I believe they retain the crank shaft, so if you are converting to 2.2 L then you will need to remove them.
Project Chill 1
#761
Posted 02 November 2013 - 11:08 AM
#762
Posted 02 November 2013 - 11:19 AM
#763
Posted 02 November 2013 - 11:41 AM
#764
Posted 02 November 2013 - 12:00 PM
you need to remove twenty of the bolts with a 15mm head and ten of the 13mm head bolts
Basically all the bolts visible when the engine is upside down
Then use a large screwdriver or small crowbar and lever off the lower crank carrier
Edited by vocky, 02 November 2013 - 12:02 PM.
#765
Posted 02 November 2013 - 12:10 PM
#766
Posted 02 November 2013 - 01:59 PM
Crank is out
Few more pics
#767
Posted 02 November 2013 - 02:35 PM
You may want to print this out for re-assembly:
http://www.speedster...nes (Z22SE).pdf
Edited by Arno, 02 November 2013 - 02:36 PM.
#768
Posted 02 November 2013 - 02:46 PM
#769
Posted 02 November 2013 - 03:05 PM
Cheers Arno The donor engine will be scrap unless anyone wants any bits from it. Will the torque setting be similar to the b207 engine
#770
Posted 02 November 2013 - 03:26 PM
should be exactly the same
#771
Posted 03 November 2013 - 06:15 PM
#772
Posted 17 November 2013 - 03:39 PM
Edited by CHILL Gone DUTCH, 17 November 2013 - 03:40 PM.
#773
Posted 23 November 2013 - 03:30 PM
#774
Posted 23 November 2013 - 03:51 PM
#775
Posted 23 November 2013 - 03:58 PM
Edited by Wreelybro, 23 November 2013 - 03:58 PM.
#776
Posted 23 November 2013 - 04:12 PM
#777
Posted 23 November 2013 - 04:51 PM
that's for the metal coolant return pipeNeed to sort extra plug near water pipe
#778
Posted 23 November 2013 - 04:56 PM
#779
Posted 23 November 2013 - 07:42 PM
Thinking of getting a TTV from Courtenay with new clutch and slave then ready to install. Just need to rob a bank to pay for it all.
how much is the ttv flywheel
#780
Posted 23 November 2013 - 09:17 PM
