Project Chill 1
#801
Posted 15 January 2014 - 12:47 PM
#802
Posted 15 January 2014 - 01:00 PM
I think the word problem is a bit strong.
So if your 313 horsies were about 277 on a hot day, or after some strong pushing on track.
Would you notice?
Edited by smiley, 15 January 2014 - 01:04 PM.
#803
Posted 15 January 2014 - 01:06 PM
#804
Posted 15 January 2014 - 01:24 PM
That's the key point in this. It's a gradual proces, so you hardly notice. (plus 277 is still a lot)
According to the germans who use the DIN70020 correction, their rule of thumb is about 3% power loss on every 10 degrees rise.
I'm also not sure how long the ecu stores/enforces the retarded ignition.
#805
Posted 15 January 2014 - 01:51 PM
#806
Posted 15 January 2014 - 07:04 PM
You all should drive your SC in this cold & damp wheather now. The Harrop pulls like a freigh train according to some...
#807
Posted 18 January 2014 - 04:39 PM
#809
Posted 24 January 2014 - 05:09 PM
Edited by CHILL Gone DUTCH, 24 January 2014 - 05:10 PM.
#810
Posted 24 January 2014 - 07:03 PM
You need to change out the thermostat housing to start with, as the Saab does not fit with an F23 box. ;-)
Edited by Exmantaa, 24 January 2014 - 07:03 PM.
#811
Posted 24 January 2014 - 07:06 PM
Thanks for the heads up, vocky also mentioned this If there will be any other issues to get the b207 in this car please let me know, I also need to swap the pipe from the water pumpYou need to change out the thermostat housing to start with, as the Saab does not fit with an F23 box. ;-)
#814
Posted 25 January 2014 - 04:40 PM
#817
Posted 25 January 2014 - 05:33 PM
Nice work Chris. Makes a good shelf that back box.
Exciting to see the engine swap has begun.
#818
Posted 25 January 2014 - 08:45 PM
#819
Posted 26 January 2014 - 07:57 AM
List of things required,
lightened flywheel,
two new side engine mounts,
plate for coil pack,
i want to change the fuel pipes, does anyone have any ideas where get these from??
and if anyone has any other ideas of things to change while the engine is out please let me know.
#820
Posted 26 January 2014 - 09:06 AM
6 user(s) are reading this topic
0 members, 6 guests, 0 anonymous users
