Project Chill 1
4396 replies to this topic
#821 CHILL Gone DUTCH
Posted 26 January 2014 - 09:43 AM
Why not leave the fuel pipes standard?
I've never liked them so close to the alternator and belt, It's worried me since I did the SC last year
#822 Hark
Hark
  • 3,443 posts
Posted 26 January 2014 - 09:51 AM
Few threads on here about possible fuel line changes. I know jg changed his, Rally did his own as well.
#823 Wreelybro
Wreelybro
  • 1,641 posts
    360 Gaming 10-Pin Bowling.
Posted 26 January 2014 - 10:07 AM
Good work Chris you're s step ahead of me now. I'm still saving for flywheel clutch and slave.
#824 chris_uk
Posted 26 January 2014 - 10:28 AM
just get a belt cover off JG, easier to fit, no worries doing it wrong and it looks decent.
#825 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 26 January 2014 - 12:21 PM
This was from a post I put up a while ago. Ive been doing a bit of ringing around trying to get the best quote for these fuel lines and fittings and this place http://www.jjcraceandrally.com/ quoted me this. Part# Description Quan Price Total APSGB0721-6 SL200-06-FT APS STAINLESS FUEL HOSE -6 PER FOOT 10 2.88 28.80 APSGBE0209-9006 SL1090-06-311 APS 90 DEGREE REUSEABLE 2 9.65 19.30 SWIVEL HOSE END -6 JIC APSGBE0209-06 SL1000-06-311 APS STRAIGHT REUSEABLE 3 3.31 9.93 SWIVEL HOSE END -6 JIC MOCHEF7-6-5 FEMALE STRAIGHT SWIVEL. 1 1.91 1.91 APSGBAN924-6 SL924-06-011 APS BULKHEAD NUT -6 JIC 2 1.54 3.08 APSGBAN832-6 SL832-06-011 APS MALE BULKHEAD FITTING -6 JIC 2 3.28 6.56 MOCHC1-1 WORM DRIVE HOSE CLAMP .37-.62IN. 6 0.26 1.56 S/C31308 RUBBER LINED P CLIP 15.9MM. SELL IN PACK OF 1 5.40 5.40 10. UK Express 0.00 76.54 15.30 Subtotal (Excl. Vat) £ Vat @ 20% Total Quoted £ 91.84 Ive took the parts from the list that Rally supplied me with so if this looks different its because there was different colours ordered on the other one meaning it looked like there was more parts. With this its the colour which you quote to the company that you would like. To get this deal just quote my name Luke Richardson and the quote number 5373996 EXP DATE 19/04/2013 Just to also let you know that this only goes back to the oem filter. You also need to order the adapters for the fuel rail from USA for this but i think JG has some of these in the pipe line.
#826 CHILL Gone DUTCH
Posted 26 January 2014 - 01:29 PM
Cheers luke will drop JG a PM,
if not i think i can get them from ebay
http://www.ebay.com/...1983163?vxp=mtr
when you say it only goes back to the fuel filter, does the other line  go back to the in fuel tank bracket thing?
Edited by CHILL Gone DUTCH, 26 January 2014 - 01:31 PM.
#827 GeorgeBC
GeorgeBC
    Needs a cheaper hobby
  • 3,138 posts
Posted 26 January 2014 - 06:49 PM
Get your arse in gear and lets get the new one in!
I would defo remove subframe whilst everything is off and treat the mating surfaces, just saying . . .
#828 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 26 January 2014 - 08:49 PM
Think they where the ones I ordered off eBay.
With one of the adaptors you buy it has a ribbed affect on it which you have to slide the other fuel line over then put a jubilee clip on to be double safe it doesn't come off. Basically you just have to cut into it and then heat it loads so that it slides over enough. You also have to make 2 brackets up, one for keeping the fuel lines straight from the fuel filter and then a second one from the fuel rail to keep them straight.
#829 CHILL Gone DUTCH
Posted 26 January 2014 - 09:11 PM
ive got plenty of bits on order GBC.
but im hoping to keep the car a long time so will have things to do next year,
Rome was not built in a day and my wallet has not got as much in it since owning this car
#830 CHILL Gone DUTCH
Posted 26 January 2014 - 09:12 PM
will deffo be doing fuel lines soon
cheers haggi
#831 chris_uk
Posted 26 January 2014 - 11:43 PM
That the bracket i made?
#832 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 27 January 2014 - 12:34 AM
Yep, that's both brackets from the scrap bits of metal.
#833 JG
JG
  • 13,612 posts
Posted 27 January 2014 - 11:20 AM
The fittings exist to go right back to the tank with aeroquip (or similar copies) fitting and braded hose.
I must admit i don't like that return coupling into the plasic pipe at all. Actually i don't really like the jublee clip on the high pressue either but that will probably be ok (it wouldn't pass any MSA inspection)
#834 CHILL Gone DUTCH
Posted 27 January 2014 - 07:58 PM
List of things required,
lightened flywheel,  [color=#ff0000;]ordered[/color]
two new side engine mounts,  [color=#ff0000;]ordered[/color]
plate for coil pack, [color=#ff0000;]ordered[/color]
i want to change the fuel pipes, does anyone have any ideas where get these from??  contemplating
[color=#008000;]and if anyone has any other ideas of things to change while the engine is out please let me know.[/color]
#835 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 27 January 2014 - 08:48 PM
What flywheel did you go for mate?
#836 CHILL Gone DUTCH
Posted 27 January 2014 - 08:52 PM
Z22se lightened fly wheel from CS
#837 Hark
Hark
  • 3,443 posts
Posted 27 January 2014 - 09:16 PM
I never managed to get one of those belt covers off JG.  Wanted one so I don't feel the need to do fuel lines but may come to it.
#838 JG
JG
  • 13,612 posts
Posted 27 January 2014 - 10:14 PM
They are only for special people :P Really though, if you really want one I've got three or four unfinished ones.
#839 CHILL Gone DUTCH
Posted 27 January 2014 - 10:16 PM
How many ££s Finished
Edited by CHILL Gone DUTCH, 27 January 2014 - 10:17 PM.
#840 JG
JG
  • 13,612 posts
Posted 27 January 2014 - 10:19 PM
Can't remember, think they were 40quid for the last lot
