One or the other is my bet. Looks too "engineered" to be just a blank/plug. My version of the Saab WIS and EPC is useless and doesn't even show the cooler at all.thermostat? pressure relief spring?
Posted 29 January 2014 - 03:46 PM
Posted 29 January 2014 - 03:53 PM
Can ask on UKSaabs if you'd like? And it's important?
Posted 29 January 2014 - 04:21 PM
Posted 29 January 2014 - 04:23 PM
Posted 29 January 2014 - 05:11 PM
thermostat, the early Saab B207 / Z20NET bypassed the oil cooler until the oil got hot enough
the group buy engines are A20NET and don't have this feature
Posted 29 January 2014 - 05:12 PM
How are you mounting the Saab oil cooler as was lead to believe won't fit past the vx220 gearbox?
I ran the Saab oil cooler for a couple of years, never noticed any difference on the road.
Posted 29 January 2014 - 05:17 PM
Good idea on older, higher viscosity oils. Not much point with the modern stuff though. They probably revised the oil grade recommendations when they removed the thermostat.
Posted 29 January 2014 - 11:17 PM
Thanks Neil.thermostat, the early Saab B207 / Z20NET bypassed the oil cooler until the oil got hot enough the group buy engines are A20NET and don't have this feature
Posted 29 January 2014 - 11:29 PM
Meanwhile in techies garage.........
Posted 30 January 2014 - 08:28 AM
Looking at those rocker covers surely they are a Joe / Lee enterprise?
Posted 30 January 2014 - 09:24 AM
I really should go and remove the shrink wrap from the new engine sat in the garage and see what that's got instead.
What Neil said, The newer Saab / A20NET engines have the oil cooler directly bolted to the block without a thermostat.
For my LSJ I modded this thermostat housing to fit with the original VX oilcooler & hoses:
Posted 31 January 2014 - 04:24 PM
Now you just need to take the jigsaw to it.
Posted 31 January 2014 - 04:30 PM
Posted 01 February 2014 - 02:28 PM
Posted 01 February 2014 - 02:50 PM
Cheers Neil, what diameter is the water feed to the oil cooler so I can buy a length of Ali pipe to bypass the oil cooler(z22se).oil pressure switch, just extend the wire and use the vx220 plug, the switch is exactly the same
Posted 01 February 2014 - 04:09 PM
fcuk
Edited by CHILL Gone DUTCH, 01 February 2014 - 04:09 PM.
Posted 01 February 2014 - 04:13 PM
not orange box,,
i meant the bypass pipes with the bleed nipples
