Project Chill 1
4396 replies to this topic
#881 CHILL Gone DUTCH
Posted 01 February 2014 - 04:22 PM
on here
or is this a bad idea to put it across these connections
#882 CHILL Gone DUTCH
Posted 01 February 2014 - 04:40 PM
scrap this question i have just found a heater matrix drawing !!!!!!
:ffs:  :ffs:  :ffs:  :ffs:  :ffs:  :ffs:  :ffs:  :ffs:  :ffs:
BRAIN IS FRIED TODAY!!
Edited by CHILL Gone DUTCH, 01 February 2014 - 04:49 PM.
#883 vocky
Posted 01 February 2014 - 05:10 PM
you need to connect the saab oil cooler into the heater circuit.
So connect one vx220 heater hose to the saab oil cooler and the other side of the saab oil cooler goes to where the original vx220 heater hose went to. The other vx220 heater hose remains untouched.
The large coolant hose connects as normal to the thermostat, except you are removing the vx220 oil cooler and using a 32mm alloy hose connector instead. You will have to modify this hose to clear the saab oil cooler.
Edited by vocky, 01 February 2014 - 05:10 PM.
#884 CHILL Gone DUTCH
Posted 01 February 2014 - 05:20 PM
you need to connect the saab oil cooler into the heater circuit.   So connect one vx220 heater hose to the saab oil cooler and the other side of the saab oil cooler goes to where the original vx220 heater hose went to. The other vx220 heater hose remains untouched.   The large coolant hose connects as normal to the thermostat, except you are removing the vx220 oil cooler and using a 32mm alloy hose connector instead. You will have to modify this hose to clear the saab oil cooler.
I assume it will be best to use the heater return on the air box side of car to go to oil cooler. No wonder the heater is not so good on a vx looking at the way it's plumbed
Edited by CHILL Gone DUTCH, 01 February 2014 - 05:26 PM.
#885 vocky
Posted 01 February 2014 - 05:26 PM
yes that was the one I used when I had the saab oil cooler
#886 CHILL Gone DUTCH
Posted 01 February 2014 - 05:34 PM
If I used the other I might get a warmer heater?? Why is the heater matrix system fed from the cooler pipes??
#887 oakmere
oakmere
  • 2,143 posts
Posted 01 February 2014 - 09:50 PM
Chris it is probably because the heater pipes work before the thermostat opens. So the oil can be heated by the water when warming up. Then as the oil gets much hotter the water keeps it cool. All of the above is a bit of a guess as I don't have the coolant circuit to hand.
#888 CHILL Gone DUTCH
Posted 05 February 2014 - 06:08 PM
More bits today
Toe links
And some aliminium pipe
Edited by CHILL Gone DUTCH, 05 February 2014 - 06:11 PM.
#889 Wreelybro
Wreelybro
  • 1,641 posts
    360 Gaming 10-Pin Bowling.
Posted 05 February 2014 - 06:40 PM
Parts hoard getting bigger Chris!
#890 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 05 February 2014 - 06:42 PM
Could you take notes of size and lenght of all your tubing and pipe work you make? Will come in handy for when me and others start our builds.
#891 CHILL Gone DUTCH
Posted 05 February 2014 - 06:51 PM
indeed i will,
i will probably have spare to
#892 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 06 February 2014 - 11:05 AM
thumbsup
#893 CHILL Gone DUTCH
Posted 09 February 2014 - 11:00 AM
Just changing slave in the clutch and got a quick question Does the new slave dosent seem to compress as much as the old one Do I have the right slave ?? Bolt holes are all the same etc and it fits
#894 CHILL Gone DUTCH
Posted 09 February 2014 - 11:03 AM
Here is a pic of the new one
Edited by CHILL Gone DUTCH, 09 February 2014 - 11:03 AM.
#895 Kieran McC
Kieran McC
  • 3,416 posts
Posted 09 February 2014 - 11:05 AM
Watch that slave cylinder seal they are easy to burst
Edited by kieranmcc, 09 February 2014 - 11:14 AM.
#896 CHILL Gone DUTCH
Posted 09 February 2014 - 11:08 AM
Maybe the old one has had it
#897 CHILL Gone DUTCH
Posted 09 February 2014 - 11:28 AM
There is no resistance in the old one
#898 oakmere
oakmere
  • 2,143 posts
Posted 09 February 2014 - 11:46 AM
Chill it should be easy to push back is the bleed nipple open? If not are you trying to compress the air trapped inside. What you must not do is extend the slave by pressurising the system with no clutch attached or you will blow the seals.
#899 CHILL Gone DUTCH
Posted 09 February 2014 - 11:52 AM
I have taken the alloy block off the g-box
#900 CHILL Gone DUTCH
Posted 09 February 2014 - 11:53 AM
I have not compressed the new one
