Project Chill 1
#901
Posted 09 February 2014 - 01:38 PM
#903
Posted 09 February 2014 - 10:16 PM
I wouldn't of touched it. Should of just bolted it on and bled it up when the engines in the car. Hope you haven't fcuked anything up.Just changing slave in the clutch and got a quick question Does the new slave dosent seem to compress as much as the old one Do I have the right slave ?? Bolt holes are all the same etc and it fits
#905
Posted 15 February 2014 - 05:39 PM
#906
Posted 15 February 2014 - 05:54 PM
#907
Posted 15 February 2014 - 05:55 PM
10mm earth wire for meAh I nearly did that but managed to save it with a telescopic magnet.
#908
Edited by CHILL Gone DUTCH, 15 February 2014 - 05:56 PM.
#909
Posted 15 February 2014 - 07:16 PM
A quick exceleration did it for me.
#910
Posted 17 February 2014 - 06:00 PM
Edited by CHILL Gone DUTCH, 17 February 2014 - 06:00 PM.
#911
Posted 17 February 2014 - 06:13 PM
#912
Posted 17 February 2014 - 06:23 PM
So am IGood progress Chris looking fwd to seeing your car complete.
#914
Posted 19 February 2014 - 02:58 PM
What manifold is it? Very shiny!
#915
Posted 19 February 2014 - 03:00 PM
It's a one off, Was part of the GB trialWhat manifold is it? Very shiny!
#916
Posted 19 February 2014 - 03:08 PM
Really? There's not much to modify on there. What do have to do to it?Also the header tank pipe will need modifying to
#917
Posted 19 February 2014 - 03:12 PM
I ended up bending the coolant bottle bracket slightly to stop the header tank feed pipe from kinkingReally? There's not much to modify on there. What do have to do to it?Also the header tank pipe will need modifying to
#918
Posted 19 February 2014 - 03:22 PM
#919
Posted 19 February 2014 - 03:30 PM
No But I have altered the pipe work for the engine coolant the water manifold could of done with a angle welding on it but I have settled for a 45' degree 32mm silicone hose If you are careful where you cut the original 19mm heater pipes you can get away with buying a 19mm U bend to complete the 19mm pipesAh, got ya. Was visualising you trying to add an additional inlet/outlet on there.
Edited by CHILL Gone DUTCH, 19 February 2014 - 03:31 PM.
#920
Posted 19 February 2014 - 07:17 PM
Unfortunately the company decided to spend more time making it shiny than checking the flange was straight so they lost the business.
Bing (1)
