Project Chill 1
4396 replies to this topic
#981 CHILL Gone DUTCH
Posted 10 March 2014 - 06:19 PM
Ok i set out today to get a full fuel learn session in but things did not go to plan,
went for a short drive with scanguage connected just to check a few things out with the tmap sensor and afr
just to confirm all is well and it was so things started well.
decided to do a fuel learn session but i could not under any circumstances get my laptop to talk to my ECU so after dissconecting everything squirting all the connections and trying again still no joy. I put my scanguage back in to see if all was well with that it wasent,  sh*t my heart sunk looms and ecu failure went through my mind,
after diconnecting the scanguage again i noticed one of the wires from the obd port had broken off so out came my soldering iron with me upside down in the footwell burning every finger with a lot of blood in my head after a hour or so i managed to get the connection remade only to notice the one next to it had broken off to so a further hour or so i managed to get this sorted at this point i was not 100% if this was my original problem so i connected up scanguage again to see if it worked
It seemed to take a long to to connect but it did so i reconnected the obd lead an my laptop and tested i held my breath NO i didnt work. So i went to connect up the scanguage only to notice a other broken cable at this point i was pissed.
so i made a cup of T
and then got back to it repaired the wire and all was good everything talking to everything else as it should.
so i warmed the car up and did a good logging session for Peter to have a look over everything
only to get a little more bad news
rather my fuel pressure is wrong or i need bigger injectors (currently on the 470 blues)
im at 90% at 6700 RPMs
so i need to check my fuel pressure does anyone no how to do this and what equipment do i need to check it??
so to round up the day it was terrible nothing achieved, loads of problems, and potentially a fuel pressure problem or i need bigger injectors.
can anyone give me any idea of how much power the blue injectors should produce ??
#982 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 10 March 2014 - 06:33 PM
fuel pressure check is easy I got a kit off ebay, about £30 http://www.ebay.co.u...=item1c3b64e2dc only thing I had to do was extend the hose so I could check the pressure while driving what power you putting out again? I ran 320bhp with 470cc ones but I had the fpr modded slightly by CMS
Edited by NickB777, 10 March 2014 - 06:35 PM.
#983 CHILL Gone DUTCH
Posted 10 March 2014 - 06:38 PM
I haven't done any power runs yet but peter said my cams are working extremely well Cheers for that nick
#984 NickB787
NickB787
  • 7,813 posts
Posted 10 March 2014 - 06:41 PM
that was just the first one I found so worth a search
#985 CHILL Gone DUTCH
Posted 10 March 2014 - 06:48 PM
Cheers nick
#986 smiley
Posted 10 March 2014 - 07:42 PM
Up to 370isch, but that is when spraying at 100%.
Peters philosophy is that the ecu does not know the difference between 90% and 100%, and is just fully open as from 90%.
That is why he likes injectors that top at 90% max at the full rev top.
#987 oakmere
oakmere
  • 2,143 posts
Posted 10 March 2014 - 08:43 PM
Sounds like a nightmare Chris. I wonder if they were on the way out when we were having issues connecting? When funds allow get a cheap secondhand netbook for car only use. Not surprised about the injectors thought you might start maxing them out. It shows the engine is breathing well though. What were the intake temps like?
#988 CHILL Gone DUTCH
Posted 10 March 2014 - 08:47 PM
Intake temps were around 56 degrees max, reving all the way to 7100 through 1st 2nd 3rd and 4th gear
Edited by CHILL Gone DUTCH, 10 March 2014 - 08:47 PM.
#989 oakmere
oakmere
  • 2,143 posts
Posted 10 March 2014 - 09:27 PM
Sounds good as it was quite mild today. The better engine breathing may be helping intake temps.
#990 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 10 March 2014 - 09:37 PM
Sounds like a nightmare. I take it your running vxr injectors now? Might be worth upgrading to the Siemens injectors or borrowing a set and trying to see if that's sorted your problem.
#991 CHILL Gone DUTCH
Posted 10 March 2014 - 09:39 PM
I will be getting some 630 Siemens déka injectors
#992 CHILL Gone DUTCH
Posted 11 March 2014 - 08:37 AM
  Up to 370isch, but that is when spraying at 100%. Peters philosophy is that the ecu does not know the difference between 90% and 100%, and is just fully open as from 90%. That is why he likes injectors that top at 90% max at the full rev top.
Does this mean when the program says your at 100% duty cycle you only at 90% and if so what is the reading when you actually at 100%
#993 JG
JG
  • 13,612 posts
Posted 11 March 2014 - 09:00 AM
The walboro pump is shit and i'm absolutely convinced it can't supply required flow rate for a 430 let alone a 600+
#994 Exmantaa
Posted 11 March 2014 - 09:05 AM
Has also to do with the "dead time" of dynamic injector switching. Until it jumps to 100% continuous on.
Just keep 90% as abs. maximum, better 80% on full swing.
#995 CHILL Gone DUTCH
Posted 11 March 2014 - 09:59 AM
I will be getting the flow rate checked peter has surgested it should be 4 bar on full throttle, I am also going to get 630cc injectors just hope the pump is up to the job?
#996 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 11 March 2014 - 10:08 AM
I'm running the next size Walbro pump on mine so might be worth considering if yours is falling.
#997 CHILL Gone DUTCH
Posted 11 March 2014 - 01:34 PM
ive had a good morning fuel learning, to llandudno and back around 150 mile round trip.
If anyone is interested i will post the logging session after the fuel learn below,
and you can view it by downloading the software for free at   http://www.obdtuner....PgDownload.html
Edited by CHILL Gone DUTCH, 11 March 2014 - 01:37 PM.
#998 CHILL Gone DUTCH
Posted 11 March 2014 - 01:40 PM
it wont upload,
is there a mod about to tell me why it wont upload
#999 CHILL Gone DUTCH
Posted 11 March 2014 - 07:34 PM
Intake temps were just above 60 degrees today it's the hardest I've worked the car since engine change.
#1000 Kieran McC
Kieran McC
  • 3,416 posts
Posted 11 March 2014 - 08:37 PM
Is it not easier to map a car on a rolling road in a more controlled enviroment
