Project Chill 1
4396 replies to this topic
#1061 CHILL Gone DUTCH
Posted 26 March 2014 - 04:07 PM
Sun is shinning so i have been working on my mapping,
Bit of good news the new transient settings peter has sent me makes the car feel very smooth and has got rid of all the knock,
however the fuel trims were out after the transient setting so i had to do a new fuel learn session and WOT learning session
I have also lost a little power, but this gives me scope to adjust the ignition settings hoping to get some of the power back without getting knock.
I also upped the rev limit to 7300 but i am not making any extra power over 7000RPM but i will leave it at 7300 to see if the new ignition settings help this.
Coloured lines are average of 2 runs in both directions
Edited by CHILL Gone DUTCH, 26 March 2014 - 04:08 PM.
#1062 CHILL Gone DUTCH
Posted 01 April 2014 - 05:24 PM
My target is met,
values for reference only
these are the two graphs since installing the 630/680cc injectors
Edited by CHILL Gone DUTCH, 01 April 2014 - 05:25 PM.
#1063 chris_uk
Posted 01 April 2014 - 05:39 PM
68 inlet temps.. getting a bit high there.
#1064 Exmantaa
Posted 01 April 2014 - 05:40 PM
Is the graph of 26th MArch with smaller injectors? That would explain the dramatic power drop @ 7000....
#1065 CHILL Gone DUTCH
Posted 01 April 2014 - 05:46 PM
No this is all since 630/680cc injectors It was all down to ignition
#1066 CHILL Gone DUTCH
Posted 01 April 2014 - 05:48 PM
Yes but I did manage this with 3.1 pulley
#1067 Exmantaa
Posted 01 April 2014 - 05:57 PM
Was there a significant change in the original timing map @7000?
And it looks like you can still win a little around 6500 to fill that area, but no idea if you already have some knock retard there.
Nice power! thumbsup
#1068 CHILL Gone DUTCH
Posted 01 April 2014 - 06:03 PM
I actually had quite a lot of knock retard from the base map which me and peter tried quite a lot of things to get rid of it, In the end I added around 3 degrees of advance and got rid of all knock, This current power run has around 0.2 of knock retard at 2300 revs which I'm putting down to the cams other than that there is no knock
#1069 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
check mine out Chris...
#1070 CHILL Gone DUTCH
Posted 01 April 2014 - 06:06 PM
  Was there a significant change in the original timing map @7000?   And it looks like you can still win a little around 6500 to fill that area, but no idea if you already have some knock retard there.   Nice power! thumbsup
I still have not found optimum ignition but for the time being I'm happy
#1071 Exmantaa
Posted 01 April 2014 - 06:10 PM
Will be good to update your engine spec list with this graph. :rolleyes:
#1072 CHILL Gone DUTCH
Posted 01 April 2014 - 06:11 PM
Please show
#1073 CHILL Gone DUTCH
Posted 01 April 2014 - 06:18 PM
Engine spec
1. Chill. 2.2 crank, forged pistons and rods stage 2 LSJ cams,lightened flywheel and balancer delete, home build with vocky input on Dutch ECU software M62 charger ported head. Hoping for 300+ maximum rev 7500 due to M62 charger, now also putting dbilas springs in, 630cc injectors
3.1 pulley
Edited by CHILL Gone DUTCH, 01 April 2014 - 06:21 PM.
#1074 NickB787
NickB787
  • 7,813 posts
Posted 01 April 2014 - 06:32 PM
they are really nice lines there you must be pleased
#1075 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 01 April 2014 - 06:42 PM
Not bad at all with the 3.1 inch pulley. I hate to think what mine would be running at if I mess around with the ignition.
#1076 CHILL Gone DUTCH
Posted 01 April 2014 - 06:50 PM
Melted linears
#1077 CHILL Gone DUTCH
Posted 01 April 2014 - 06:51 PM
Always nice when you hit your target
#1078 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 01 April 2014 - 08:10 PM
True but I still might see what it could make.
#1079 CHILL Gone DUTCH
Posted 02 April 2014 - 11:58 AM
93dB at oulton this morning
#1080 CHILL Gone DUTCH
Posted 02 April 2014 - 05:09 PM
There might of been quite a bit of heat sink on that particular run as I spent a lot of time changing parameters and temps were high But I will be checking this after croft
