Project Chill 1
#1141
Posted 16 April 2014 - 07:13 AM
#1142
Posted 16 April 2014 - 07:33 AM
#1143
Posted 16 April 2014 - 09:09 AM
#1144
Posted 16 April 2014 - 10:36 AM
#1145
Posted 19 April 2014 - 05:34 PM
Got a very good set of cl5+ for sale front and back :-)
im going for cl5+ along with some SS hoses
are these brand new lee,
if so how much
#1146
Posted 20 April 2014 - 04:51 PM
#1147
Posted 20 April 2014 - 05:00 PM
Mintex 1144 would not last a whole trackday I managed to get through 4/5 of a set if 1155 at croft earlier in the monthMintex 1144 were reasonable at 300 BHP, but even RC6 is not good enough beyond 350 BHP IMO. The brakes on the car were never intended for serious stopping from high speeds IMO. Just my 2p worth.
#1148
Posted 24 April 2014 - 02:44 PM
Delivery arrived today so I really should make a start,I must make a start this week,
Lots to do and the national is coming
1. Change engine oil and filter,
2. Brake fluid
3. Brake pads ( 1155 are not up to the job ) and I loved these once
4. Need new rear tires
5. Would like to get geo done but don't think it will be done before national ohh and get new toe links fitted
#1149
Posted 24 April 2014 - 04:41 PM
My brakes were awful for ages after fitting braided hoses. Biggest mistake i've made, other than buying a VX in the first place! Get a vacuum bleeder.
#1150
And whatever you do, don't drink it!
#1151
Posted 24 April 2014 - 04:48 PM
#1152
Posted 24 April 2014 - 04:51 PM
Just means it's designed to be used in cars with DPFs too, it's reached the same performance level as the A/B specs.
Brakes are okay now, but took me ages to sort them out. Made no difference too.
#1153
Posted 25 April 2014 - 04:10 PM
I was seconds away from ordering some of these. My fluid overheats on track days and this seems to be a well thought of help for that. My existing hoses are probably as old as the car. Can you expand a bit on the problems you encountered? Would you just replace like for like if you could do it again?
#1154
Posted 25 April 2014 - 04:19 PM
#1155
Posted 25 April 2014 - 04:38 PM
#1156
Posted 25 April 2014 - 04:53 PM
I've been on track hard braking for over 40 minutes and not had an ounce of brake fade. Another bonus for still having NA power. Will put some cooling ducts in when I get round to it though.
I've got NA power which is why it concerns me. Not sure it's the pads (RS14s) just everything seems to get really hot hence me considering these hoses. The fluid boils (changed it yesterday). The fronts were smoking heavily after a session at the recent Croft day so had to go back out and cool them down properly.
Sorry if this is spamming Chills thread, but hopefully it will be of some use.
#1157
Posted 25 April 2014 - 05:07 PM
What fluid are you using? I wonder if your brakes are dragging, causing the extra heat. I use halfords Racing fluid, standard disks, braided lines and RC6 pads.I've got NA power which is why it concerns me. Not sure it's the pads (RS14s) just everything seems to get really hot hence me considering these hoses. The fluid boils (changed it yesterday). The fronts were smoking heavily after a session at the recent Croft day so had to go back out and cool them down properly. Sorry if this is spamming Chills thread, but hopefully it will be of some use.I've been on track hard braking for over 40 minutes and not had an ounce of brake fade. Another bonus for still having NA power. Will put some cooling ducts in when I get round to it though.
#1158
Posted 25 April 2014 - 05:46 PM
I really don't think there's any added cooling to be had by switching to braided, as they are then covered in plastic. The rest of the pipe work is metal so you have some cooling effect there, best way to protect against the fluid boiling is regular changes. My issues were all to do with actually changing the hoses, it introduced so much air into the system, especially the 2 pot calipers, that they felt awful for ages. It took lots of pressure bleeding and hitting with mallets just to get the car usable. I honestly think that braided hoses only show up old hoses when they have started to perish, mine were okay and would be a similar condition to yours '51 plate and 80 odd thousand miles when I changed them.I was seconds away from ordering some of these. My fluid overheats on track days and this seems to be a well thought of help for that. My existing hoses are probably as old as the car. Can you expand a bit on the problems you encountered? Would you just replace like for like if you could do it again?Brakes are okay now, but took me ages to sort them out. Made no difference too.
#1159
Posted 25 April 2014 - 06:09 PM
#1160
Posted 25 April 2014 - 08:43 PM
That is really good wear rates. How are they are brake dust? In answer to Zoobeef - Pagid RS14s all round, Halfords Racing dot 4 fluid, standard plain discs. Hopefully my fluid change will help. And yes, I def have some issues with the calipers not releasing properly, handbrake related I think. Taking it to Phoenix Motorsport for 8am tomorrow to get it sorted before my 1000 mile round trip.I like cl, they feel nice and wear extremely well.. Or maybe they are just old and knackered.. Still have 10mm of pad left after 6 trackdays and 3 years of driving..
6 user(s) are reading this topic
0 members, 6 guests, 0 anonymous users
