Project Chill 1
#1201
Posted 22 May 2014 - 02:36 PM
#1202
Posted 22 May 2014 - 04:56 PM
There has been quite a lot of work going on with Peter concerning non OEM cams, im just waiting to hear back from Peter concerning the non oem cams, there has been more changed than just fuel learn
Did you change anything particular, or just a decent fuel map learned...??Also the car now revs freely at all revs Even below 2000rpm when previously there seemed to be a lot of cam overlap up to 2000 So the car also needs a fuel learn session before national and a fine tune.
Yep big changes and mine is amazing to drive in 4 gear at 20mph where as before you had to be in second gear.
Huh? Both of you please explain
Peter has been experimenting with non OEM settings which for most people who have tried the new settings has seen massive improvement below 2000 rpm which previously caused the car to judder which was described as cam overlap, It has a lot to do with ignition setting and the natural egr of the cams, Peter has asked me not to share my settings as it could be different for different people, He has also indicated that he will be very soon updating each calla ration with the new settings on a individual bases and is hoping to make a announcement over the weekend on his forumAh OK, so Peter made some progression with his cam / idle settings.
#1203
Posted 22 May 2014 - 05:29 PM
#1204
Posted 22 May 2014 - 05:36 PM
#1205
Posted 22 May 2014 - 05:37 PM
#1206
"Natural EGR of the cams"??
Curious to Peter's explanation on his forum. With the LSJ ecu we're experimenting too with idle timing settings, the coast down timing and throttle body opening parameters to tame the idle behaviour with cams.
Edited by Exmantaa, 22 May 2014 - 05:38 PM.
#1207
Posted 22 May 2014 - 05:46 PM
I never mentioned idle, The idle settings are a other story and sure will come good in the future"Natural EGR of the cams"?? Curious to Peter's explanation on his forum. With the LSJ ecu we're experimenting too with idle timing settings, the coast down timing and throttle body opening parameters to tame the idle behaviour with cams.
#1208
Posted 22 May 2014 - 05:52 PM
[color=rgb(68,68,68);font-family:Calibri, sans-serif;font-size:16px;]This test works on the principle of exhaust gas recycling induced by the longer opening times of the camshafts at low rpm. At lower rpm’s and lower power there is quite a bit of exhaust gas sucked back into the engine. This will give the same effect as opening an EGR valve and can be used to dramatically increase the ignition timing in this range of the map. Which has a positive effect on the drivability.[/color]
[color=rgb(68,68,68);font-family:Calibri, sans-serif;font-size:16px;]does this help examantaa[/color]
Edited by CHILL Gone DUTCH, 22 May 2014 - 05:56 PM.
#1209
Posted 22 May 2014 - 06:24 PM
#1211
Posted 23 May 2014 - 04:12 PM
#1212
Posted 23 May 2014 - 04:22 PM
Edited by CHILL Gone DUTCH, 23 May 2014 - 04:32 PM.
#1213
Posted 23 May 2014 - 04:46 PM
#1214
Posted 23 May 2014 - 04:57 PM
I will have one, one day kieren, looking forward to it at the nationalThat is easy compared to the M32 ones.
#1215
Posted 23 May 2014 - 05:43 PM
That bad really. Sounds like I'm going to have fun when I come to do it.Looser than before Luke It's not a nice job in fact it's now taken over as the worse job on a vx The width of the new cables do cause a few issues, if they go wrong again I'm selling up
#1216
Posted 23 May 2014 - 06:19 PM
Later I thought thst you indeed mend cam reversion with this "EGR".[color=rgb(68,68,68);][font="Calibri;"]This test works on the principle of exhaust gas recycling induced by the longer opening times of the camshafts at low rpm. At lower rpms and lower power there is quite a bit of exhaust gas sucked back into the engine. This will give the same effect as opening an EGR valve and can be used to dramatically increase the ignition timing in this range of the map. Which has a positive effect on the drivability.[/color][/font]
[color=rgb(68,68,68);][font="Calibri;"]does this help examantaa[/color][/font]
you can run more advance down low through this, and also goof for mileage.
(and more exh back pressure will amplify this effect Smiley. ;-)
Edited by Exmantaa, 23 May 2014 - 06:21 PM.
#1217
Posted 23 May 2014 - 06:25 PM
#1218
Posted 27 May 2014 - 04:23 PM
Lots to do and the national is coming
1. Change engine oil and filter,
2. Brake fluid
3. Brake pads ( 1155 are not up to the job ) changed to CL5+
4. Need new rear tires got new tires
5. Would like to get geo done but don't think it will be done before national ohh and get new toe links fitted
6. fuel learn session for the new revs below 2000 rpm
#1220
Posted 30 May 2014 - 08:23 PM
Lots to do and the national is coming but im not going
1. Change engine oil and filter,2. Brake fluid3. Brake pads ( 1155 are not up to the job )changed to CL5+4. Need new rear tiresgot new tires5. Would like to get geo done but don't think it will be done before national ohh and get new toe links fitted6. fuel learn session for the new revs below 2000 rpm
Bing (1)
