Project Chill 1
4396 replies to this topic
#1241 CHILL Gone DUTCH
Posted 23 June 2014 - 02:26 PM
Tried that and ended up with all this oil exiting from the filter, So I'm introducing the positive pressure to the system
Edited by CHILL Gone DUTCH, 23 June 2014 - 02:32 PM.
#1242 chris_uk
  • 10,060 posts
Posted 23 June 2014 - 02:30 PM
I just threw my cam cover breather into a bottle.
#1243 fezzasus
Posted 23 June 2014 - 02:34 PM
You tried it with an open PCV valve?
#1244 CHILL Gone DUTCH
Don't you have your Pcv orifice closed in the head
#1245 CHILL Gone DUTCH
Posted 23 June 2014 - 02:35 PM
Yes but doesn't work under heavy track use
#1246 CHILL Gone DUTCH
Posted 23 June 2014 - 02:38 PM
I'm hoping the positive pressure will keep the Pcv valve on the inlet manifold open under heavy loads and replacing the nasty fumes with fresh air
#1247 Steve.i.am
Steve.i.am
  • 990 posts
  • Interests:Bends
Posted 23 June 2014 - 02:56 PM
The PCV valve is only opened by presence of vacuum in the intake manifold. It closes off as soon as the intake manifold goes from vaccuum to +ve pressure (ie boost). If it didn't do this you'd be pushing boost pressure through it into the crankcase.
All I can see happening with what you've done here is under load all the crap you used to chuck out the breather to the back of the car will now be going through your inlet.
#1248 CHILL Gone DUTCH
Posted 23 June 2014 - 03:10 PM
Do you not think the vacuum will pull the gases and leave the oil?
#1249 smiley
Posted 23 June 2014 - 03:12 PM
Yes that is the horrid theory.
I am on the same as Mr Chill with PCV open on the B207 but with a catch tank between cam cover and inlet.
Did a few hours of track, and still need to check the tank.
May do that this evening B)
#1250 CHILL Gone DUTCH
Posted 23 June 2014 - 03:23 PM
  Yes that is the horrid theory.   I am on the same as Mr Chill with PCV open on the B207 but with a catch tank between cam cover and inlet. Did a few hours of track, and still need to check the tank.   May do that this evening B)
Let me no the results, do you have a separator ??
#1251 Steve.i.am
Steve.i.am
  • 990 posts
  • Interests:Bends
Posted 23 June 2014 - 03:24 PM
I wish there were some easy solution to this - can try mate but I doubt it.
When under load (which is where the problem is) you no longer have a vacuum on the inlet anyway. I can't see how you wont get the same stuff out the breather now as before - only difference is where it is going...
I have my breather routed to the same place you did - at offside rear of the car and I get oily deposits all over the back of it on trackdays like you - although nowhere as bad as yours. I am going to move the breather back to somewhere near the side air intake - and higher up. I am wondering with the exit being so low its only making the oil loss out of it worse.
#1252 CHILL Gone DUTCH
Posted 23 June 2014 - 03:37 PM
  I wish there were some easy solution to this - can try mate but I doubt it.   When under load (which is where the problem is) you no longer have a vacuum on the inlet anyway. I can't see how you wont get the same stuff out the breather now as before - only difference is where it is going...   I have my breather routed to the same place you did - at offside rear of the car and I get oily deposits all over the back of it on trackdays like you - although nowhere as bad as yours. I am going to move the breather back to somewhere near the side air intake - and higher up. I am wondering with the exit being so low its only making the oil loss out of it worse.
When I tried any other position than behind the wheels I got nasty smells in the cabin
#1253 vocky
Posted 23 June 2014 - 03:42 PM
I still have zero oil or oil mist coming from my OEM cam breather pipe, GM seem to know what they were doing when they spent a small fortune creating the PCV system  ;)
#1254 Steve.i.am
Steve.i.am
  • 990 posts
  • Interests:Bends
Posted 23 June 2014 - 03:51 PM
Hmm - is this more of an SC issue really? IE causing a lot more blow by & crankcase pressure..?
#1255 CHILL Gone DUTCH
I'm hoping from the same, Time will tell
#1256 chris_uk
  • 10,060 posts
Posted 23 June 2014 - 03:53 PM
same here, i must of done umpteen trackdays and road miles and it was about 1/2 way up my bottle..
i hardly get any really.
#1257 CHILL Gone DUTCH
Posted 23 June 2014 - 03:57 PM
  same here, i must of done umpteen trackdays and road miles and it was about 1/2 way up my bottle..    i hardly get any really.
I think vocky means his is fitted to inlet like mine
Edited by CHILL Gone DUTCH, 23 June 2014 - 03:57 PM.
#1258 chris_uk
  • 10,060 posts
Posted 23 June 2014 - 04:01 PM
i was referring to the amount really.
#1259 CHILL Gone DUTCH
Posted 23 June 2014 - 04:03 PM
If you have none or next to none is it not a good idea to go to the oem setup which I'm trying
#1260 PaulCP
PaulCP
  • 6,064 posts
Posted 23 June 2014 - 05:33 PM
I don't believe so. On previous tuning attempts (anybody remember the AMD days), well before mine was SCd, it always threw out oil through the breather, so much so that the TB became caked in the blow by substance hence reducing power before it was cleaned out. Following that experience the breather was removed from the inlet and re routed into a catch tank. I think it is a simple as some engines "breathe" more heavily than others when tweaked. If not then mine has been fubared for the past 10 years
Edited by PaulCP, 23 June 2014 - 05:35 PM.
