Yes I see. As for SC'd cars I still remain to be convinced the PCV is of any help at all to the problems we have. As soon as there is any boost, it'll be shut and so just the same in that scenario as if it were blocked off. It only does anything at small throttle openings where it pulls crankcase vapours via the valve, and air is drawn into the cam breather. As soon as it shuts the flow on the cam breather reverts to being outward and it's back to square one. Anyway lets see what chill finds on the tests.I think it is a simple as some engines "breathe" more heavily than others when tweaked. If not then mine has been fubared for the past 10 years
Project Chill 1
#1261
Posted 23 June 2014 - 06:06 PM
#1262
Posted 23 June 2014 - 06:20 PM
Edited by CHILL Gone DUTCH, 23 June 2014 - 06:24 PM.
#1263
Posted 23 June 2014 - 07:25 PM
I am on the same as Mr Chill with PCV open on the B207 but with a catch tank between cam cover and inlet. Did a few hours of track, and still need to check the tank. May do that this eveningLet me no the results, do you have a separator ??
No seperator. Tank was empty.
I do need to do a few more trackdays though. August 1 Zandvoort is a full day, which should give more info.
#1264
Posted 23 June 2014 - 07:32 PM
Sounds promising Did you have a diffrent arrangement before which gave you a issue like mine ??No seperator. Tank was empty. I do need to do a few more trackdays though. August 1 Zandvoort is a full day, which should give more info.
Let me no the results, do you have a separator ??I am on the same as Mr Chill with PCV open on the B207 but with a catch tank between cam cover and inlet. Did a few hours of track, and still need to check the tank. May do that this evening
#1265
Posted 23 June 2014 - 07:44 PM
Yes, smal filter on the catch tank, instead of back into inlet pipe.
Same as you. Tank filled pretty quick, and filter drowned with oil.
This positive pressure thingy is sounding positive for now
(preliminairy conslusion, as i need to do more track miles)
Edited by smiley, 23 June 2014 - 07:45 PM.
#1266
Posted 23 June 2014 - 07:46 PM
Sounds good !! Watch this space and I hope to have similar resultsYes, smal filter on the catch tank, instead of back into inlet pipe. Same as you. Tank filled pretty quick, and filter drowned with oil. This positive pressure thingy is sounding positive for now
#1267
Posted 23 June 2014 - 07:49 PM
Also the first trackday (well hours) ever i did, without having to top up oil afterwards.
If chris_uk's bottle is airtight to the hose, it could explain the same(isch) result.
Edited by smiley, 23 June 2014 - 07:51 PM.
#1268
Posted 24 June 2014 - 02:54 PM
#1269
Posted 24 June 2014 - 04:30 PM
#1270
Posted 24 June 2014 - 07:30 PM
Chill, when I take my engine out i'll pull the laminovas and show you what running with PCV for approx 10 months looks like.
#1271
Posted 24 June 2014 - 07:32 PM
#1272
Posted 26 June 2014 - 06:59 PM
#1273
Posted 26 June 2014 - 07:06 PM
No separator at the moment but there no signs of oil in the inlet Straight inInteresting this. Await to see what happens at Anglesey. I suppose if there's any significant oil going back into your intake the exhaust will smoke as its burnt? If there's anyone following you on the day maybe they can watch out for any sign of that. Have you got any oil separator or catch between the cam breather and inlet at the moment Chill - or is it currently straight in?
#1274
Posted 26 June 2014 - 10:33 PM
For the cost of a basic oil catch tank it must be worth adding a cheap, one even if it's just to make it easy to monitor whats happening without having to pull the intake off every time?
#1275
Posted 26 June 2014 - 10:40 PM
Or just use a small bottle like chris_uk did if it's just for an experiment.
Just make sure the hose seals the bottle neck to make it air tight.
#1276
Posted 26 June 2014 - 10:45 PM
#1278
Posted 27 June 2014 - 11:27 AM
Are they just new design of the gp2's or are they a completely different shock?
#1279
Posted 27 June 2014 - 11:41 AM
The fronts seem to be the same,
the rears have a longer top bit im not sure whats happening on the inside but when i give gaz a call to pick the old ones up i will ask if anything internally are diffrent
#1280
Posted 29 June 2014 - 05:28 PM
Edited by CHILL Gone DUTCH, 29 June 2014 - 05:29 PM.
Bing (1)
