Project Chill 1
4396 replies to this topic
#1361 CHILL Gone DUTCH
Posted 11 September 2014 - 11:14 AM
I chose not to vent the boot as this boot is diffrent from oem and is also thicker rubber so hopfully this won't need doing again anytime soon
#1362 oakmere
oakmere
  • 2,143 posts
Posted 11 September 2014 - 05:38 PM
You can't sell up yet I still haven't had a pax ride. Some times difficult to justify keeping these cars if not getting used much. Then you go for a drive and think there's no way am selling.
Work on Saturdays Martin but when it's up and running will text you and take you for a ride before she goes
Cheers
#1363 CHILL Gone DUTCH
Posted 19 September 2014 - 09:40 AM
Well I'm in a bit of a pickle Changed pads to CL5+ before Anglesey came to bleed brakes today to find there is no pad left Yes you heard right 1 track day used a full set of cl5+ pads This now leaves me needing a set of track pads ASAP Anyone no where I can pick some up from today ??
#1364 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
  • Interests:Performance cars!
Posted 19 September 2014 - 09:56 AM
I put a cable tie round my cv boot...stops it expanding and rubbing. worked a charm.
#1365 CHILL Gone DUTCH
Posted 19 September 2014 - 02:53 PM
Oh well that's a other £400 spent on the car New discs and some new CL RC6 pads Does it ever stop ??????????? I still can't believe I only got one trackday out of a set off pads which cost £250
#1366 Kieran McC
Kieran McC
  • 3,416 posts
Posted 19 September 2014 - 03:41 PM
You cant run a VX on a Fiver
#1367 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 19 September 2014 - 10:14 PM
Whaaaaaat? I've just had these fitted. Had RS14s which lasted 15k miles including 6 track days before now so slightly concerned at that catastrophic pad consumption! I'm sure I've read ChrisUK reports on these pads saying he's driven 1000s of miles on RC5+ with several track days...
#1368 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 19 September 2014 - 10:16 PM
What discs you running?
#1369 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 19 September 2014 - 10:45 PM
I've done one track day on mine and a bit of road driving and they still look new. Something not right with yours mate.
#1370 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 20 September 2014 - 03:50 AM
I got just under 10k from my cl5. More than half worn down and brakes not as sharp. What state were the pads after the trackday chris??
#1371 CHILL Gone DUTCH
Posted 20 September 2014 - 05:51 AM
There is nothing left on the front pads rear are a bit better but well worn , I can only put in down to the disc which I now have I'm not sure what make the disc is but there going In the bin It came to a surprise to me to
#1372 pete-r
pete-r
  • 2,771 posts
Posted 20 September 2014 - 06:10 AM
That sucks, I've been recommended an upgrade to RC5+ from my 1144 but not if that's the wear rate. You on track this weekend? I'm at llandow today.
#1373 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 20 September 2014 - 07:43 AM
I have run cl5+ and never had a wear rate like yours, something wrong there. What discs are you using? don't worry if they are cheap units I use cheap ones and ok you throw them away after 2.5 sets of pads but they do the job. Where did you purchase the pads from?
#1374 siztenboots
Posted 20 September 2014 - 07:49 AM
Are they grooved?
#1375 CHILL Gone DUTCH
Posted 20 September 2014 - 07:54 AM
Here is a pic of them
Grooved
#1376 CHILL Gone DUTCH
Posted 20 September 2014 - 08:56 AM
New pads are here ..
#1377 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 20 September 2014 - 09:24 AM
Running the grooves that way round will increase wear rates. They're meant to be the other way to expel gas and pad dust with the centrifugal force. I've heard people run them the way you have to get a better initial bite but £250 per track day in pad is a lot of money for a bit more bite!
#1378 Wreelybro
Wreelybro
  • 1,641 posts
    360 Gaming 10-Pin Bowling.
Posted 20 September 2014 - 09:37 AM
Also depends which way the internal vents point.
#1379 CHILL Gone DUTCH
Posted 20 September 2014 - 10:16 AM
Believe it or not the grooves run the other way on the other side of car but the vents between the two plates are pointing in the right direction The new discs are plain so I only have to look at internal direction
#1380 Kieran McC
Kieran McC
  • 3,416 posts
Posted 20 September 2014 - 10:31 AM
The way Chris runs his is the same as mine , Have done quite afew track days this year with this set up pads are fine, Cheap discs and PF pads.
6 user(s) are reading this topic
0 members, 6 guests, 0 anonymous users
