Project Chill 1
4396 replies to this topic
#1441 CHILL Gone DUTCH
Posted 08 December 2014 - 07:35 PM
I'm sure your copying me lol
Not copying Just doing my own way
Edited by CHILL Gone DUTCH, 08 December 2014 - 07:35 PM.
#1442 TFD
TFD
  • 607 posts
Posted 08 December 2014 - 08:51 PM
Nice to bring up a SR20DE picture...
Never seen the return going to an exhaust with all the sr20's I've seen. Either breatherfilter or catchcan in between en return to intake pipe behind the maf.
Ran catchcan in between and blocked the pvc connection on my S14 SR20DET. Worked great. All fumes had to pass the catchcan.
Interested how you work this out though ;-)
Edited by TFD, 08 December 2014 - 08:53 PM.
#1443 Arno
Arno
  • 1,238 posts
Posted 09 December 2014 - 09:33 AM
Also think I'm going to be creating the vacuume in the exhaust system rather than the inlet To stop the oily sh*t going into the inlet
Be sure to fit it in the exhaust after the cat (and secondary lambda) to prevent oil damage/contamination to cat or sensors and plug or close it off during an MOT test as it will introduce free oxygen in the exhaust that will throw off the MOT tester calculated lambda value and make it too high to get a pass.
#1444 CHILL Gone DUTCH
Posted 09 December 2014 - 09:51 AM
  Be sure to fit it in the exhaust after the cat (and secondary lambda) to prevent oil damage/contamination to cat or sensors and plug or close it off during an MOT test as it will introduce free oxygen in the exhaust that will throw off the MOT tester calculated lambda value and make it too high to get a pass.   Bye, Arno.
Cheers for the heads up Arno
#1445 Arno
Arno
  • 1,238 posts
Posted 10 December 2014 - 01:19 PM
Oh.. And make sure you fit a flame-arrestor (aka. metal gauze filter) in the pipework connection so any igniting oil vapour can't travel back up the pipe to the engine and give a big bang...
#1446 CHILL Gone DUTCH
Posted 10 December 2014 - 01:49 PM
@ Arno 👍 Have you had any expierience with the pipe into the exhaust from the head ??
#1447 FLD
Posted 10 December 2014 - 02:32 PM
I've used them on pro-stocks.  From my experience you need the connector tube close the the merger on the manifold which doesn't suit your purposes.  This might be because I was running open manifolds though.  The ones I was using had a gause in to stop any flashback and they worked fairly well.  IIRC the angle you weld into the exhaust is fairly key to their function.
#1448 Arno
Arno
  • 1,238 posts
Posted 10 December 2014 - 06:07 PM
Not personally, but I have seen it done on several US V8 engines.
As FLD mentions the location and shape of the nozzle in the exhaust is critical for it to work well (or not..) so it develops a low-pressure area.
Should be enough out there on the internet if you dig around to get some good info on this.
#1449 CHILL Gone DUTCH
Posted 10 December 2014 - 08:13 PM
Cheers will be doing a lot of research before getting it welded in I'm glad there are people which think it is possible to get this working on our cars
#1450 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 10 December 2014 - 08:28 PM
Will you be doing any extra cooling mods for the intake mani? Like lee's second intercooler or using meth kit?
#1451 CHILL Gone DUTCH
Posted 10 December 2014 - 09:31 PM
I will be doing one step at a time so I can see what's happening with each modification First will be exhaust keeping M62 Then possibly add Harrop and see how I get on will probably need a bigger fuel pump
Edited by CHILL Gone DUTCH, 10 December 2014 - 09:32 PM.
#1452 oakmere
oakmere
  • 2,143 posts
Posted 11 December 2014 - 10:39 AM
Might be worth trying the LS4 throttle as well I think Lee is using one. The Harrop is more efficent so should produce less heat of the correct pulley is used. If it was mine I would run a large pulley and aim for 320-340 BHP that is reliable and dosn't fall away on track.
#1453 oakmere
oakmere
  • 2,143 posts
Posted 11 December 2014 - 10:49 AM
Not sure I would bother with the exhaust mod. There are to many unknowns regarding how well it will work and problems it ma cause. Just spend the money on a proper baffled catch tank not the cheap ebay specials. OEM's use catch tanks so they do work.
#1454 CHILL Gone DUTCH
Posted 11 December 2014 - 11:41 AM
I was thinking about putting my current 3.1 pulley on it but will also be experimenting with pulley sizes once I've added one thing at a time
#1455 CHILL Gone DUTCH
Posted 29 December 2014 - 05:44 PM
Father Christmas has been today
#1456 CHILL Gone DUTCH
Posted 29 December 2014 - 05:45 PM
And
#1457 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 29 December 2014 - 06:47 PM
A dirty old Harrop and a loud exhaust welcome to my club lol nice ;-)
#1458 CHILL Gone DUTCH
Posted 29 December 2014 - 06:50 PM
Going to stick a big pulley on it (wacko) It's certainly dirty don't no where joe has stored it
#1459 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 29 December 2014 - 06:51 PM
nice pressies :) what you aiming for?
#1460 CHILL Gone DUTCH
Posted 29 December 2014 - 06:55 PM
Controlling inlet temps
7 user(s) are reading this topic
0 members, 7 guests, 0 anonymous users
