Project Chill 1
4396 replies to this topic
#1461 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 29 December 2014 - 07:01 PM
Has the exhaust been resprayed? It doesn't look like it's been zircotecd.
#1462 CHILL Gone DUTCH
Posted 29 December 2014 - 07:06 PM
Don't no ask joe
#1463 CHILL Gone DUTCH
Posted 01 January 2015 - 03:13 PM
Well the new year is upon us 2015 As stated earlier I will be putting on the Harrop 3.1 pulley and 3" exhaust as a attempt to keep temps lower I may also be lowering my RPM for the same reason I will also over the next week start to strip the old M62 off and check the inlet and laminovas to check if the have collected much oil residue since changing the PCV to fully open, I will also be putting the catch tank in with some home made separators in there, this way I should see how much oil is being sucked through. I did want to put the pipe from cam cover straight to exhaust but this can be put on hold for now, the car is not using as oil as previously with the cam cover pipe open to atmosphere. I will also be servicing the car oil filter fuel filter and possibly changing the air filter setup but this will be on hold along with LS4 throttle body So my hopes for first stage Cooler inlet temps Hoping the 3" exhaust is going to be quiet enough for track days Not after any extra power despite having a 2.8 and 2.9 pulley with the charger of joe going to stick with the 3.1 pulley. Going to try get the car back on the road in late February early March to get the mapping sorted Happy new year Chris
#1464 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 01 January 2015 - 03:18 PM
Sounds good Chris and looking forward to seeing your result.
#1465 smiley
Posted 01 January 2015 - 03:19 PM
Very curious about this, as all scary pictures so far were from systems with pcv closed.
#1466 CHILL Gone DUTCH
Posted 01 January 2015 - 03:23 PM
I've accepted that they are going to need cleaning as part of the yearly service
#1467 Kieran McC
Kieran McC
  • 3,416 posts
Posted 01 January 2015 - 03:30 PM
#1468 Kieran McC
Kieran McC
  • 3,416 posts
Posted 01 January 2015 - 03:34 PM
Joes car with the 3" exhaust and Harrop was never good on a noise test. Decibell reducers were required at Snet to even get close to a static pass.
#1469 CHILL Gone DUTCH
Posted 01 January 2015 - 03:38 PM
It's been modified since then but If it's still to loud I will extend it from exit with a other silencer external to the car ( removable)
#1470 Nev
Posted 02 January 2015 - 02:11 PM
Hi Chill, in regards to venting the crank/cam pressure directly to the exhaust, isn't it likely that the exhaust pressure will be quite high, such that it might not release the pressure from the engine? Have you seen/read much about this sort of venting which has had success, or are you speculating/testing, as I am interested.
Edited by Nev, 02 January 2015 - 02:12 PM.
#1471 siztenboots
Posted 02 January 2015 - 02:15 PM
the exhaust system see exhaust valve pulses every 180° crank turn
#1472 Nev
Posted 02 January 2015 - 02:17 PM
I think in a turbo car that is less likely to be prevolant (due to the turbines modulating the flow).
I suppose the key thing to know is:
X= Max exhaust pressure at say 6000 RPM
Y= Max crank case pressure as say 6000 RPM
If X < Y then venting will work.
#1473 CHILL Gone DUTCH
Posted 02 January 2015 - 02:22 PM
http://vibrantperfor...roducts_id=1243
#1474 CHILL Gone DUTCH
Posted 02 January 2015 - 02:28 PM
#1475 CHILL Gone DUTCH
Posted 02 January 2015 - 02:42 PM
not as straight forward as i first thought it would be but i am keen to try and get it to work,
if i can get it to work im sure it will benefit the SC guys
#1476 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 02 January 2015 - 03:25 PM
interesting idea
#1477 CHILL Gone DUTCH
Posted 02 January 2015 - 03:27 PM
I check valve will also have to be installed to stop exhaust gasses going back into engine
#1478 siztenboots
Posted 02 January 2015 - 03:31 PM
no way to reuse the egr valve port?
#1479 CHILL Gone DUTCH
Posted 02 January 2015 - 03:41 PM
Worth a read here http://www.audizine....CV-into-exhaust
Edited by CHILL Gone DUTCH, 02 January 2015 - 03:43 PM.
#1480 CHILL Gone DUTCH
Posted 02 January 2015 - 03:44 PM
Saab doesn't have one Also you need it after O2 sensors and wideband
