Project Chill 1
4396 replies to this topic
#1481 siztenboots
  • 26,613 posts
Posted 02 January 2015 - 03:54 PM
I thought they did ,
http://www.saabcarpa...r-saab-9-3.html
#1482 CHILL Gone DUTCH
Posted 02 January 2015 - 04:00 PM
I thought they did ,   http://www.saabcarpa...r-saab-9-3.html
No already blocked up on the B207 engines From group buy
Edited by CHILL Gone DUTCH, 02 January 2015 - 04:04 PM.
#1483 CHILL Gone DUTCH
Posted 02 January 2015 - 04:07 PM
Here is a more complicated version with the oil draining back into sump and just the gassed going into exhaust but I'm guessing some oil would still get to exhaust
But not necessary you could just catch tank it or not even bother just let it escape into exhaust
The whole point of this is so we have a full functioning positive crankcase ventilation and stop the laminovas being blocked
Edited by CHILL Gone DUTCH, 02 January 2015 - 04:09 PM.
#1484 CocoPops
CocoPops
  • 17,181 posts
Posted 02 January 2015 - 06:11 PM
Won't that put it under vacuum conditions? Thus actively sucking out air/oil?
#1485 CHILL Gone DUTCH
Posted 02 January 2015 - 06:14 PM
Only under heavy load Which is what happens when it's connected to inlet
#1486 vocky
Posted 02 January 2015 - 06:19 PM
what about using sticky's method of connecting the oil filler cap to the PCV system ?
#1487 FLD
http://www.j-body.or...38&t=185338&p=1 http://www.j-body.or...186733&t=186733 Some links that may help. From what I've read the plastic inserts aren't great for high boosted motors and are usually damaged (melted) if the cover is powdercoated. The reason GM weld in a larger fitment is to slow the gas speed out of the breather. This lets the oil mist drop out. There are various other versions where people have fitted multiple breathers to the channels on in the rocker cover. Hope this helps.
#1488 CHILL Gone DUTCH
Posted 02 January 2015 - 06:23 PM
Wouldn't this bypass and have less resistance than original outlet and in effect bypass the separator and pull more oil out
#1489 FLD
Posted 02 January 2015 - 06:25 PM
It's not about resistance (or at least not in my head!) its about low flow speed so the droplets condense out. If you have one, high resistance, route out then the air speed will be damn fast and the droplets will stay suspended.
#1490 The Batman
Posted 02 January 2015 - 06:26 PM
I have a jegs oil separator somewhere
#1491 vocky
Posted 02 January 2015 - 06:42 PM
connect it up as if it was another cam cover breather, so double the available air flow in or out, depending on what the engine is doing at the time
#1492 CHILL Gone DUTCH
Posted 02 January 2015 - 06:47 PM
This will still cause my laminovas to oil up as it is now
#1493 vocky
Posted 02 January 2015 - 06:49 PM
it is indeed a quandary  :beat:
#1494 CHILL Gone DUTCH
This is the kind of conversation I'm after about this To help come up with a solution Don't mean to sound blunt
#1495 vocky
Posted 02 January 2015 - 06:51 PM
I know, but it does make your head hurt when trying to think of a viable solution  :lol:
#1496 CHILL Gone DUTCH
Posted 02 January 2015 - 06:53 PM
All I want to do is replace the vacuum or pressure from inlet with Using something else my thought was the exhaust can create the vacuum like the inlet just a bit more delayed I just need to find a way to get fresh air in when the inlet Pcv orifice is allowing air in to the manifold ( which in my head this is what pulls fresh air in to cam cover ) but this can't be done from exhaust
#1497 CHILL Gone DUTCH
Posted 02 January 2015 - 06:56 PM
I need some kind of two way valve controlled by exhaust vacuum
#1498 vocky
Posted 02 January 2015 - 06:58 PM
Air should go into the cam cover via the breather hose, the inlet manifold creates the vacuum, too much vacuum or too much pressure from the supercharger alters the PCV and thus the problems occur
Edited by vocky, 02 January 2015 - 06:59 PM.
#1499 CHILL Gone DUTCH
Posted 02 January 2015 - 06:59 PM
I even considered using the saab oil turbo return In the B207
Edited by CHILL Gone DUTCH, 02 January 2015 - 07:00 PM.
#1500 Nev
Posted 02 January 2015 - 07:01 PM
At the moment on my car I just vent the crank case + cam breathers via 1" tubes to under the engine with a gauze filter on the end of each. As a result there is a quite a lot of oil loss like this due to lack of condensation. I probably lose something like a cupful of oil like this every 150 miles. Also, this means the area near the gauze filters (the N/S/R wishbone) is covered in oily muck - good for keeping rust away though ! LOL
Edited by Nev, 02 January 2015 - 07:09 PM.
