Project Chill 1
4396 replies to this topic
#1501 CHILL Gone DUTCH
Posted 02 January 2015 - 07:02 PM
Air should go into the cam cover via the breather hose, the inlet manifold creates the vacuum, too much vacuum or too much pressure from the supercharger alters the PCV and thus the problems occur
Once the Pcv valve gets more pressure in the inlet manifold compared with engine side of my the Pcv valve it closes which is very quickly on our boosted engines
#1502 vocky
Posted 02 January 2015 - 07:04 PM
blank off the inlet manifold vacuum port and fit a one way valve with pressure control into the cam cover, just drill and fit a fitting into the cam cover and the other end would need to go to a vacuum port.
I have done something similar on mine to reconnect the PCV
Edited by vocky, 02 January 2015 - 07:04 PM.
#1503 CHILL Gone DUTCH
Posted 02 January 2015 - 07:05 PM
At the moment on my car I just vent the crank case + cam breathers via 1" tubes to under the engine with a gauze filter on the end of each. As a result there is a quite a lot of oil loss like this due to lack of condensation. I probably lose a cupful of oil like this every 100 miles. Also, this means the area near the gauze filters (the wishbones) are covered in oily muck - good for keeping rust away though ! LOL
This seems to be happening to me since going higher than stage 2 SC So I put it in to the inlet manifold and the car uses a lot less oil But the trade of is the laminovas throttle body and supercharger gets oily Which dosent help with cc
#1504 CHILL Gone DUTCH
Posted 02 January 2015 - 07:09 PM
blank off the inlet manifold vacuum port and fit a one way valve with pressure control into the cam cover, just drill and fit a fitting into the cam cover and the other end would need to go to a vacuum port. I have done something similar on mine to reconnect the PCV
Do you mean the orifice as CS do? If so this is basically like this all the time due to the boost from onlet manifold closing the Pcv valve in the inlet ??
#1505 vocky
Posted 02 January 2015 - 07:11 PM
blank the oriface.
Then control the amount of vacuum the PCV system has, with the adjuster. Having no vacuum is bad for the PCV, the pistons create air pressure and this needs to be kept under control.
Edited by vocky, 02 January 2015 - 07:11 PM.
#1506 CHILL Gone DUTCH
Posted 02 January 2015 - 07:15 PM
@ vocky
Couldn't we create this from the turbo oil return,
For pulling gasses out
And simply put a filter straight on cam cover to let air in
#1507 CHILL Gone DUTCH
Posted 02 January 2015 - 07:24 PM
This way it creates a open system rather than a troublesome sealed system
#1508 CHILL Gone DUTCH
Posted 02 January 2015 - 08:03 PM
Does anyone think this will work ??? Or have I lost the plot 😭😭🙀👴
Edited by CHILL Gone DUTCH, 02 January 2015 - 08:05 PM.
#1509 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 02 January 2015 - 10:58 PM
You lost me at orifice. :lol:
Edited by ArticMonkey, 02 January 2015 - 10:59 PM.
#1510 FLD
Posted 03 January 2015 - 09:36 AM
The exhaust systems do work but I've only seen them on pro-stocks etc. If you search 'oil separator' on ebay you'll find quite a few centrifugal ones that return oil to the sump and connect to the inlet. These should minimise fouling but htere's no reason you cant vent it to atmosphere via a filter.
#1511 CHILL Gone DUTCH
Posted 03 January 2015 - 11:32 AM
Was going to vent cam cover to atmosphere for clean air and keep the separator ( spiral ) sealed to the exhaust setup What do you think this way the whole engine benefits from cooker cleaner air As for orifice it dosent really matter as once car is creating boost ( more pressure in the inlet manifold than the crank ) then it is closed anyway If I can get a bit of confidence on this I will be doing it
#1512 Nev
Posted 03 January 2015 - 11:56 AM
Venting PCV fumes back into the inlet is bad. This is because the fumes in the crank case are devoid of oxygen and because they are bloody hot, so by venting this gas back into the inlet track means that your cylinders will see lower oxygen content and higher inlet charge temps. This is not good for power at all and also will mean you could run rich.
In "old skool" cars, manufacturers always used to vent PCV to atmosphere. It is only the modern emissions laws that now force them to re-circulate any crank pressure. From that you can draw your own conclusion about what would be best. :)
Edited by Nev, 03 January 2015 - 11:56 AM.
#1513 Arno
Arno
  • 1,238 posts
Posted 03 January 2015 - 12:24 PM
Eg. MANN Provent 200
http://www.inlinefil.../FMH-3931070550
Originally a truck/generator/agriculture product, but very popular on offroaders and many boosted setups.
Drain hose on these can/should be connected to the sump below the oil level (otherwise needs a 1-way valve) so any collected oil drains back into the engine sump.
#1514 siztenboots
Posted 03 January 2015 - 12:54 PM
do you also struggle for brake servo vacuum?
iirc b207 has a cam driven vacuum pump?
#1515 CHILL Gone DUTCH
Posted 03 January 2015 - 02:06 PM
do you also struggle for brake servo vacuum?   iirc b207 has a cam driven vacuum pump?
No problem but I do use the cam driven b207 pump
#1516 CHILL Gone DUTCH
Posted 03 January 2015 - 02:08 PM
Venting PCV fumes back into the inlet is bad. This is because the fumes in the crank case are devoid of oxygen and because they are bloody hot, so by venting this gas back into the inlet track means that your cylinders will see lower oxygen content and higher inlet charge temps. This is not good for power at all and also will mean you could run rich.   In "old skool" cars, manufacturers always used to vent PCV to atmosphere. It is only the modern emissions laws that now force them to re-circulate any crank pressure. From that you can draw your own conclusion about what would be best. :)
This is what I will be avoiding with the proposed setup in drawing Can anyone see any issues with it not working or causing more damage that the current setup which is a standard PCV system oem
#1517 CHILL Gone DUTCH
Posted 03 January 2015 - 02:14 PM
Probably will end up with more than 250 kW but other than that it looks like the answer
Cheers
#1518 oakmere
oakmere
  • 2,143 posts
Posted 03 January 2015 - 05:03 PM
I have said it before but I would try one of these proper separators first before adding all the complexity of the exhaust method. The way I see it the original method worked but you were getting oil sucked through the TB contaminating the laminovers. By adding an oil air separator should solve the problem, the one above or an air compressor filter would be my choice.
#1519 vocky
Posted 03 January 2015 - 05:10 PM
@ vocky
this is just plain wrong for the z22se engine.
Air goes into the cam cover.
The PCV requires a vacuum to remove the excess air pressure inside the engine.
Sod using the exhaust for a vacuum source, use the saab servo pump and an inline filter  :P
#1520 Arno
Arno
  • 1,238 posts
Posted 04 January 2015 - 09:11 AM
Probably will end up with more than 250 kW but other than that it looks like the answer Cheers
You could always go with the 400 or even 800 model
Lineup and some nice background info:
https://www.mann-hum...ent_en_2013.pdf
