Project Chill 1
4396 replies to this topic
#1541 CHILL Gone DUTCH
Posted 09 January 2015 - 06:14 PM
Do you think it could be squared off and saved ?
#1542 fezzasus
Posted 09 January 2015 - 06:42 PM
I would recommend welding it back in.
#1543 CHILL Gone DUTCH
Posted 09 January 2015 - 06:44 PM
Anyone got a pic so I can see how much has been removed ?
#1544 CHILL Gone DUTCH
Posted 09 January 2015 - 06:52 PM
And how much of a problem do you think the porting has been
#1545 fezzasus
Posted 09 January 2015 - 07:31 PM
http://s12.photobuck...G_3485.jpg.html
I'd say it's a pretty big problem, you won't be compressing much air as it'll be bleeding past the rotors.
Edited by fezzasus, 09 January 2015 - 07:32 PM.
#1546 FLD
Posted 09 January 2015 - 07:45 PM
I'd say it could be squared off but I would mark a straight line to the rotor and put it in a mill. Once straightened out it should be OK. I wouldn't weld it in as you'd likely have to line bore the case for the rotors again. Welding the case without deformation will be virtually impossible.
#1547 JG
JG
  • 13,617 posts
Posted 09 January 2015 - 07:46 PM
Its just an NA with some blades going round in the intake...
#1548 fezzasus
Posted 09 January 2015 - 07:48 PM
brrrap
#1549 fezzasus
Posted 09 January 2015 - 07:49 PM
TBH I'd probably just junk it.
#1550 oakmere
oakmere
  • 2,143 posts
Posted 09 January 2015 - 11:09 PM
I would not junk it keep as Spair of for parts.
#1551 CHILL Gone DUTCH
Posted 10 January 2015 - 05:27 AM
👍 It's not done me anthrax yet, might explain the noise
#1552 fezzasus
Posted 10 January 2015 - 10:37 AM
I don't see what spares you're going to get from it, the casing is matched to the rotors, and you'll damage all the bearings pulling them out, as well as the obvious point that new bearings are cheap so there's absolutely no point reusing them.
Supercharger kits are only worth the money they fetch because of the inlet manifold, the supercharger on it's own is worth very little, hence why I said junk it.
#1553 smiley
Posted 10 January 2015 - 12:13 PM
brrrap
As proven at 3:55. (next to the JK tyres of course)
#1554 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 10 January 2015 - 12:15 PM
Hmmmm looks like my used supercharger is worth more than yours now Chill :ninja:
#1555 CHILL Gone DUTCH
Posted 10 January 2015 - 02:35 PM
Mine works well enough There not many m62 which have gone beyond 304.9hp 😜 And only 3.1 pulley There's not much up with it
Edited by CHILL Gone DUTCH, 10 January 2015 - 02:39 PM.
#1556 FLD
Posted 10 January 2015 - 03:19 PM
It might be OK if you straighten out the hole to match the rotors. That's essentially what porting them does. You can take off a few extra mm and lengthen the hole. It'll be fine.
#1557 CHILL Gone DUTCH
Posted 12 January 2015 - 06:43 PM
A other half day on the car today,
Mmmmmm
The Harrop is a tight fit It's bloody close to the Tmap sensor which needed cutting and filing and also the charger gets very close to the Bit that the map sensor fits to ( closest to bulk head)
Also managed to snap one of the manifold bolts in the head so that slowed things up a bit, which led me to removing the manifold again,
I did get the fuel filter changed, dropped the oil and changed oil filter
Looks like I'm going have to do some uri fellow type spanner bending tomoz to get to the bolts at the back of the HARROP and also the injectors are really close to the charger
What I'm describing is simply the HArrop is to big for the vx
Any way I'll stick with it and see what other issues there will be
#1558 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 12 January 2015 - 07:04 PM
pig of a job I remember spending half a day, no joke, removing the stupid bolts at the back of the thing, get a baulkhead cutout sorted, saves so much time, also make certain you m8 the manifold bolts rather than m6
#1559 CHILL Gone DUTCH
Posted 12 January 2015 - 07:08 PM
Cheers Nick 👍
#1560 Kieran McC
Kieran McC
  • 3,416 posts
Just about to do a cut out in the fire wall, It will make fitting and working on a Harrop alot easier. Dave Hardwick engineering do a nice panel . Thanks Teckie..
