Project Chill 1
#1561
Posted 12 January 2015 - 07:09 PM
#1562
Posted 12 January 2015 - 07:13 PM
Its in handDid you get a Harrop Kieren
#1563
Posted 12 January 2015 - 11:28 PM
A other half day on the car today, Mmmmmm The Harrop is a tight fit It's bloody close to the Tmap sensor which needed cutting and filing and also the charger gets very close to the Bit that the map sensor fits to ( closest to bulk head) ************** Looks like I'm going have to do some uri fellow type spanner bending tomoz to get to the bolts at the back of the HARROP and also the injectors are really close to the charger What I'm describing is simply the HArrop is to big for the vx Any way I'll stick with it and see what other issues there will be
TMAP sensor needs some tweaking for the Harrop. ;-)
And remove the rear + front gearbox mount bolt so you can tilt the engine a bit. Makes access behind the bulkhead a bit easier.
(What dual pass have you fitted? If you have a cast ZZP plate this can foul the Harrop too.)
#1564
Posted 13 January 2015 - 06:49 AM
#1565
Posted 13 January 2015 - 08:09 AM
C'mon Chill, I want to see this beast rolling with its harrop.
#1566
Posted 13 January 2015 - 08:10 AM
#1567
Posted 13 January 2015 - 09:18 AM
Modified standard dual pass plate is fine with the Harrop
#1568
Posted 13 January 2015 - 12:02 PM
#1569
Posted 13 January 2015 - 12:36 PM
#1570
Posted 13 January 2015 - 12:54 PM
Harrop is on
#1571
Posted 13 January 2015 - 01:47 PM
you can say that again, well doneHarrop is on
#1572
Posted 13 January 2015 - 02:12 PM
#1573
Posted 13 January 2015 - 02:20 PM
X(
spent!
#1574
Posted 13 January 2015 - 03:19 PM
#1575
Posted 13 January 2015 - 06:17 PM
#1576
Posted 13 January 2015 - 06:31 PM
#1577
Posted 13 January 2015 - 07:48 PM
I'm running 2.9 or I have a 2.8
Hmmm... are you joining the 400+ club
#1578
Posted 13 January 2015 - 07:51 PM
#1579
Posted 13 January 2015 - 07:52 PM
#1580
Posted 13 January 2015 - 07:54 PM
