How much pressure am I likely to make
What boost or fuelpressure?
Stock fuelpressure is 3,8-4,0 barg base pressure. Add boost on top of that...
(Boost, try to keep it around 1,3- 1,4 barg @ max rpm, or you loose blower efficiency.)
Posted 14 January 2015 - 05:09 PM
Posted 14 January 2015 - 07:18 PM
Posted 14 January 2015 - 07:52 PM
Yes, 3.0 bar.
(but the newer stainless B207 rail is a bit tricky to fit. Use the Z22SE rail and if possible with raiser blocks and injector insulaors.
Edited by Exmantaa, 14 January 2015 - 07:53 PM.
Posted 14 January 2015 - 07:57 PM
Edited by CHILL Gone DUTCH, 14 January 2015 - 07:58 PM.
Posted 19 January 2015 - 03:19 PM
Edited by CHILL Gone DUTCH, 19 January 2015 - 03:21 PM.
Posted 20 January 2015 - 08:02 AM
Posted 20 January 2015 - 02:33 PM
Edited by FLD, 20 January 2015 - 02:35 PM.
Posted 20 January 2015 - 02:44 PM
Posted 20 January 2015 - 02:45 PM
Posted 20 January 2015 - 02:48 PM
Posted 20 January 2015 - 02:52 PM
Posted 20 January 2015 - 02:53 PM
Posted 20 January 2015 - 02:55 PM
Posted 20 January 2015 - 03:02 PM
Posted 20 January 2015 - 03:07 PM
Posted 20 January 2015 - 03:12 PM
That's the hole point of the catch tank with separators in the cool air fow To remove the oil residueT piece would work into tb charcoal pipe then apart from might make laminovas dirtyy
Posted 20 January 2015 - 03:13 PM
Posted 20 January 2015 - 03:16 PM
Posted 20 January 2015 - 03:21 PM
Posted 20 January 2015 - 03:26 PM
