Project Chill 1
4396 replies to this topic
#1701 CHILL Gone DUTCH
Posted 24 February 2015 - 04:14 PM
Look joe
#1702 TFD
TFD
  • 607 posts
Posted 24 February 2015 - 07:29 PM
Put one of my SS fuel lines on today
Expected it to be easier
When putting the red collar over the fuel pipe how hard should it be to screw it on ?
What thread sizes are you using? Railthread, AN thread etc. Thanx!
#1703 CHILL Gone DUTCH
Posted 24 February 2015 - 07:31 PM
An-6
#1704 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 24 February 2015 - 10:59 PM
Looking good. What route did you go down in the end with the PCV system?
#1705 CHILL Gone DUTCH
Posted 24 February 2015 - 11:15 PM
As soon as I've proven catch tank I'm going oem If catch tank is not enough ( filter goes black ) I will be spending money on a fancy separator But still oem
#1706 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 24 February 2015 - 11:59 PM
No worrys. I'm still undecided in what to do but I thinking drilling and tapping a hole on the rocker cover above the pcv opening is the route I'm doing.
#1707 CHILL Gone DUTCH
Posted 25 February 2015 - 07:25 AM
Oem on the intake ( between air filter and throttle body ) but I will be shortening the route for when engine is breathing in Low load with two one way valves and a T piece will draw it later as I love a good drawing
#1708 CHILL Gone DUTCH
Posted 25 February 2015 - 07:42 AM
#1709 CHILL Gone DUTCH
Posted 25 February 2015 - 08:47 AM
Does anyone no of a three way valve which would allow from cam both ways When it's sucking from inlet it closes filter off and vice versa My only worry with the latest drawing is air will just pull in from the small filter under vacuum
#1710 oakmere
oakmere
  • 2,143 posts
Posted 25 February 2015 - 09:14 AM
Third time lucky
Still think this is your best bet.
#1711 CHILL Gone DUTCH
Posted 25 February 2015 - 09:25 AM
how about this martin slight change
#1712 oakmere
oakmere
  • 2,143 posts
Posted 25 February 2015 - 09:41 AM
Looks good. Put the fuel filter by the TB intake pipe to make sure the catch tank is working ok 👍
#1713 CHILL Gone DUTCH
Posted 26 February 2015 - 07:27 PM
These arrived today
#1714 CHILL Gone DUTCH
Posted 27 February 2015 - 04:15 PM
All ready for Sunday including pcv ststem
#1715 oakmere
oakmere
  • 2,143 posts
Posted 27 February 2015 - 07:53 PM
Hope the mapping goes well Chill.
#1716 CHILL Gone DUTCH
Posted 27 February 2015 - 08:00 PM
I can't see Why it shouldn't Just waiting for dry roads I'm looking forward to driving it again
Edited by CHILL Gone DUTCH, 27 February 2015 - 08:01 PM.
#1717 Exmantaa
Posted 27 February 2015 - 09:37 PM
You did the brake servo vacuum completely with  the Saab pump? Any difference in brake performance/feel?
#1718 CHILL Gone DUTCH
Posted 28 February 2015 - 12:35 PM
No difference in feel apart from when braking and accelerating at the same time ( brakes are better )
#1719 CHILL Gone DUTCH
Posted 28 February 2015 - 12:36 PM
Also did get occasional hard peddle which I haven't had since
#1720 Bargi
Bargi
  • 4,483 posts
Posted 28 February 2015 - 09:07 PM
It'll make bugger all difference.
When I thought my issue was vacuum I bought one of these pumps with a vacuum switch.
Initially started with it kicking in after 2 pumps of the brake pedal (which didn't stop the hard pedal) and eventually I tried it on constantly and still no difference. It also made no difference just to normal braking as well.
You have about 3 pumps before you're out of vacuum in the servo. The length of time you hold the pedal down for makes no difference, once it's held down it uses the same amount vacuum weather you hold it for 1 second or 10.
If you can recreate the problem I will guarantee removing the rear right ABS sensor will fix it, I'll buy you beer all night at the national if it doesn't.
If you've ever had it at the end of a long straight and you've got a lot of speed and momentum (ie you're pushing for dear life) you'll have found it takes a good second or so before you get normal braking again.
All this time you're foot is off the accelerator and it's making good vacuum, yet you'll find it takes a lot less than a second for the servo to get up to full vacuum and much less to get enough for assistance.
Still don't believe me?
Start the car, have someone pull the vacuum pipe from the servo, you push the brake pedal (which is hard), then get the other person to attach the pipe and watch how quickly your pedal drops.
You do need to do this pretty fast as the engine will start revving up because of the "leak" you've just created :)
Edited by Bargi, 28 February 2015 - 09:08 PM.
    Bing (1)
