Project Chill 1
#1741
Posted 02 March 2015 - 09:44 AM
#1742
Posted 02 March 2015 - 09:56 AM
I say with optimized timing 350 can be done on an 80mm.
Of course much of that power will be gone once the sun comes out.
Let´s see.
#1743
Posted 02 March 2015 - 10:00 AM
Maybe from a one of power runI say with optimized timing 350 can be done on an 80mm. Of course much of that power will be gone once the sun comes out. Let´s see.
#1744
Posted 02 March 2015 - 12:48 PM
#1745
Posted 02 March 2015 - 12:53 PM
Your temps have always been low luke Which must be how your higher power levels Are achieved Can I post the comparison graph of your and mine ?It's a weird one I must say but looking at your graphs compered to mine at 380pk on a 2.9 inch pulley I have lower inlet temps. I can't work out why mine is breathing so well.
Edited by CHILL Gone DUTCH, 02 March 2015 - 12:56 PM.
#1746
Posted 02 March 2015 - 12:59 PM
#1747
Posted 02 March 2015 - 01:05 PM
Your head flows better due to the oversized (and waisted?) valves. Better flow = less boost/back pressure = less temperature
#1749
Posted 02 March 2015 - 01:25 PM
Edited by NickB777, 02 March 2015 - 01:26 PM.
#1750
Posted 02 March 2015 - 01:28 PM
#1751
Posted 02 March 2015 - 01:55 PM
Vocky did the work and the same as what chill has had done except mines a z22se engine and not Saab. GM Racing Valves 0,5mm Oversized Supertech Dual Valve Springs Ported Exhaust Ports Wiesco Pistons 8.9:1 Comp 0.20 OversizedLuke who did the porting work on your engine and what was done?
Edited by haggi961, 02 March 2015 - 02:03 PM.
#1753
Posted 02 March 2015 - 02:28 PM
#1754
Posted 02 March 2015 - 03:40 PM
we also need a definitive tyre radius
and weight
1000kg with a driver I'm a bit surprised.
Had mine corner weighted at Mr Bentleys it was [color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]889kg with setup below.[/color]
You telling me you're all 100+KG? (says me who is! )
Actually tyre size is pretty critical, added and extra 2.5cm circumference in OBDTuner and gained 10bhp
15 litres fuel
SC'd with pro-alloy rad
Amp and Sub Box (moulded fibreglass type)
1 x OEM and 1 x lightweight seat
TDs
Std mani and Milltek exhaust
Std brake discs
no hard/soft top on
Saab sump with few extra litres of oil
888's all round
#1755
Posted 02 March 2015 - 03:42 PM
#1756
Posted 02 March 2015 - 03:54 PM
Edited by NickB777, 02 March 2015 - 03:55 PM.
#1757
Posted 02 March 2015 - 04:09 PM
It may be worth finding out from Vocky if more work was done to yours Luke as Chill's was part of the Saab engine production line from last year so less may have been done? Knowing what was done to Chill's head it could have been opened up quite a bit more and the intake side was untouched. When ramming Harrop amouns of air through the head fitting oversized valves and more extensive porting could show large gains.
Luke's cylinder head had different porting than the others mentioned
#1758
Posted 02 March 2015 - 04:35 PM
#1759
Posted 02 March 2015 - 04:41 PM
#1760
Posted 02 March 2015 - 04:46 PM
Bing (1)
