Project Chill 1
#1761
Posted 02 March 2015 - 04:46 PM
#1762
Posted 02 March 2015 - 04:48 PM
Light weightI am feeling great at 69 kg :-)
#1763
Posted 02 March 2015 - 04:50 PM
I lied :-)Light weightI am feeling great at 69 kg :-)
#1764
Posted 02 March 2015 - 05:07 PM
#1765
Posted 02 March 2015 - 05:14 PM
But can be seen in your logs as running lower boost with a certain pulley...
(Boostpressure is simply a measure of restriction. )
#1766
Posted 02 March 2015 - 07:07 PM
#1767
Posted 02 March 2015 - 10:06 PM
only one i can find, it isnt my final one tho
#1768
Posted 02 March 2015 - 10:10 PM
Where you shivering when you did that run, Chris?
#1769
Posted 02 March 2015 - 10:32 PM
nope. you north we are hard you see...
#1770
Posted 02 March 2015 - 10:40 PM
#1771
Posted 02 March 2015 - 10:47 PM
Maybe I should have stuck with the original question. Parkinsons then?
#1772
Posted 02 March 2015 - 10:51 PM
#1773
Posted 02 March 2015 - 11:11 PM
i meant up north.. doh!
16c external temp is mild
#1774
Posted 02 March 2015 - 11:21 PM
It was the shaky lines I was worried about.
#1775
Posted 02 March 2015 - 11:46 PM
dunno, like i said it was one of the first runs i actually did..dont know where my latest ones are and its been so long since i opened up tuner i cant even remember how to get a graph, and i dont know where my info is saved either lol
#1776
Posted 02 March 2015 - 11:47 PM
#1777
Posted 03 March 2015 - 10:20 AM
Can you give more information vocky ??Luke's cylinder head had different porting than the others mentionedIt may be worth finding out from Vocky if more work was done to yours Luke as Chill's was part of the Saab engine production line from last year so less may have been done? Knowing what was done to Chill's head it could have been opened up quite a bit more and the intake side was untouched. When ramming Harrop amouns of air through the head fitting oversized valves and more extensive porting could show large gains.
#1778
Posted 03 March 2015 - 10:49 AM
This wobbly ness could also be down to the downforce chris runs and probably causing the power to be lower than it really isonly one i can find, it isnt my final one tho
This is where a RR would give more accurate power readings as the would be no air resistance
#1779
Posted 03 March 2015 - 10:54 AM
#1780
Posted 03 March 2015 - 09:40 PM
What he said ^^^^^
Downforce from Chris' car affecting the lines on the graph and the power output of the run? If that's the case then I'm not believing a single Dutch ECU graph ever again
