Project Chill 1
4396 replies to this topic
#1841 smiley
Posted 06 April 2015 - 12:32 PM
Where is the report button?
Press Alt + F4 for that one.
Edited by smiley, 06 April 2015 - 12:32 PM.
#1842 FLD
Posted 06 April 2015 - 05:47 PM
This is basically racism Where is the report button?
It's the red button with the cross in it; top right of your screen.
Lotus bouy!
#1843 TFD
TFD
  • 607 posts
Posted 06 April 2015 - 06:17 PM
Interested in how 8" works with obd-tuner and windows.
Was looking for an Android tablet to run Torque Pro in the VX(thanx for pointing out)  instead of running classic gauges. Running obd at the same time would be great.
#1844 CHILL Gone DUTCH
Posted 06 April 2015 - 09:19 PM
I wouldent like to go any smaller But spot on
#1845 CHILL Gone DUTCH
Posted 10 April 2015 - 03:46 PM
Just posting this here for my project thread
Copied from other thread
I'm going to make a statement on this subject which might suprise some,
HArrop is not worth having
I've been able to do some good testing with help from dutch software
Here is power graph from M62 and 2.5 tullet exhaust
This is what happened when I put the Harrop and 3" exhaust
And the car felt alive at this point I was very happy with the Harrop and exhaust but after doing some logging etc etc I had a feeling that the car was running lean especially at the top end of Rev range
Do I swapped out the walbro 255 pump and put in 455 pump,
And did some girl learning etc etc
And this happened
Nearly 30 HP down and the car was not alive and keen as it was before
So I think I was right that the car was running lean
Anyway this is where the car is and nothing I've tried keeping the fuel fuel ratios WOT fuel ratio at 11.8
Both M62 and Harrop are running 3.1 pulleys
And everything other than what I've mentioned are the same
I'm that disappointed with it I'm tempted to try the M62 with the 3" exhaust for comparison reasons
Yes I could change the fuel ratio to bring some of the power back but don't won't to risk the engine
#1846 fezzasus
Posted 10 April 2015 - 09:03 PM
You need to separate the comparison into two section:
1. Under 5000 rpm
Here it looks like the graph of the harrop has a greater gradient, meaning the power increases at a greater rate with RPM. This will go back to the comment that it feels like it's pulling more at low RPM, torque measurements of Harrop cars vs. Eaton M62 would agree with that.
2. Above 5000 rpm.
Both graphs seem to have issues above 5000 rpm, most noticeably on the Harrop. I would say if these issues were eliminated you would be capable of much power (drawing a line following the gradient, you would get close to 400 bhp.
Now, it's a case of identifying the issue. This breaks down into two factors; fuel and air. Since you have started addressing the fuel one, let's focus on that. What duty cycle are the injectors at? Can you use that to calculate if your fuel pump is providing enough fuel - are the fuel pipe diameters wide enough for that rate of fuel flow?
Next step is airflow. Exhaust should be fine, assume biggest issue is inlet. I assume you're running a TMAP? In that case I would say the inlet manifold is not too restrictive (69 deg. C not bad), what about the air filter? Other cars have managed more than 300 bhp with the same manifold. What crankcase ventilation did you end up using? Could you be pumping a lot of crankcase gasses back into the inlet (effectively hot, dead air)
Edited by fezzasus, 10 April 2015 - 09:05 PM.
#1847 CHILL Gone DUTCH
Posted 10 April 2015 - 09:18 PM
Hi Tom I have come up with a few things which could be the issue ( mechanically ) which I will check 1. Boost leak 2. Belt slip ( possible due to shop only having a 1290 when I think a 1280 would be more suitable 3. Reached the capacity of efficient power from inlet manifold 4. Air filter which is due to be changed ( currently have a old Apex ) 5. Something else
#1848 fezzasus
Posted 10 April 2015 - 09:22 PM
Is it a real Apexi? I know I bought a fake from ebay
also, dibs
#1849 CHILL Gone DUTCH
Posted 10 April 2015 - 09:24 PM
I came from a reputable retailer so hope so But it's past its best
#1850 CHILL Gone DUTCH
Posted 11 April 2015 - 12:50 PM
While messing with car today
Thought I would look at the filter on the Pcv system is working well
Clean as a whistle with a small puddle of oil in the catch tank so this seems to be working well
Ordered a smaller belt
Will try that first before doing anything rash like taking Harrop off
Which means parcel shelf seat out to get to the bolts
#1851 smiley
Posted 11 April 2015 - 01:53 PM
Here's a run from a harrop on a 2.0
It get's cut off to soon by the dyno guy, so at 7600 it should do around 320/330 (same as you)
He's also running  a safe pully (80mm)
Just look at how smooth the powerline should go.
Something does not go a 100% in the high rpm on your's.
Edited by smiley, 11 April 2015 - 01:54 PM.
#1852 techieboy
Posted 11 April 2015 - 01:56 PM
But remember the smoothness of the line will depend on how much data smoothing the dyno software applies.
#1853 CHILL Gone DUTCH
Posted 11 April 2015 - 01:58 PM
Don't forget mine is on the road smiley so might get a occasional hiccup I'm thinking my filter is to small going to buy a big one capable of 400 hp Also going to change belt ( 1280 ) to see if there was a bit of slip up at high rpm
#1854 CHILL Gone DUTCH
Posted 11 April 2015 - 02:01 PM
The interesting bit is at 4000 rpm mine is pulling a bit harder ( dependant on how accurate my power measurement is ) but dies off above 5000
#1855 CHILL Gone DUTCH
Posted 11 April 2015 - 04:35 PM
1. Under 5000 rpm
2. Above 5000 rpm.
This what i ended up doing with the pcv system,
dont think this is problem but i could just put it back to oem to prove this,
its how its been since putting the harrop on
#1856 fezzasus
Posted 11 April 2015 - 06:16 PM
No, I don't think that's the issue either. I think going for the low cost, easy wins like air filter and belt are a good starting point. to reiterate, I don't think you've met the limitation of the manifold, as others are getting higher power.
#1857 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 11 April 2015 - 07:00 PM
not certain why your down on power there,,,,, I was reading your post about the filter worth a try to start with, we need to get together and try to get them sorted. I have ported my head but don't know about others.
Edited by NickB777, 11 April 2015 - 07:00 PM.
#1858 CHILL Gone DUTCH
Posted 11 April 2015 - 07:11 PM
Yes we do nick Will see how things go after I change the filter and belt And take it from there Hopefully before next weekend Nick do you no the exact external diameter of the flange so I can order my filter Still waiting for mine to come from joe,🎣🎣
#1859 oakmere
oakmere
  • 2,143 posts
Posted 11 April 2015 - 07:25 PM
Chill Make sure you use the correct 76mm pipe to connect the filter to the TB not the 70mm CS supply, every little helps.
#1860 CHILL Gone DUTCH
Posted 11 April 2015 - 07:27 PM
Yes will do Not planning on having any restriction before charger
    Bing (1)
