Project Chill 1
#1861
Posted 11 April 2015 - 08:19 PM
#1862
Posted 12 April 2015 - 09:13 AM
Yes will do Not planning on having any restriction before charger
Also try to keep the biggest pipe diameter you can from the filter to the TB and then fit a reducer piece at or close to the TB to bring it to the correct size.
Eg. if your new filter has a 110MM attachement for a pipe, keep it 110MM to close to the TB and then reduce to the TB size at that point.
Bigger surface area/diameter of the pipe means lower air speeds for the same volume/sec which pretty much directly translates into less pressure drop pre-TB.
#1863
Posted 12 April 2015 - 09:28 AM
Would it be better to get a larger bit on air filter and reduce toTB As I can choose what size outlet on the TB side of filter??Also try to keep the biggest pipe diameter you can from the filter to the TB and then fit a reducer piece at or close to the TB to bring it to the correct size. Eg. if your new filter has a 110MM attachement for a pipe, keep it 110MM to close to the TB and then reduce to the TB size at that point. Bigger surface area/diameter of the pipe means lower air speeds for the same volume/sec which pretty much directly translates into less pressure drop pre-TB. Bye, Arno.Yes will do Not planning on having any restriction before charger
#1865
Posted 12 April 2015 - 09:30 AM
Edited by CHILL Gone DUTCH, 12 April 2015 - 09:31 AM.
#1866
Posted 12 April 2015 - 09:46 AM
#1867
Posted 12 April 2015 - 10:20 AM
You'd have to look at the fitment and how straight you can get the pipe to fit.
If that's all not going to be too much of a problem I'd presonally go for a nice big bore. Look at the common (silicone) hose sizes and see what matches up best.
If your LS4 TB needs a 75/76mm hose then for instance you can use a 102mm pipe and use a reducer like this (shortened as much as possible on the TB side to let the taper end just at the TB flange) and a ali coupler to the first straight pipe from the filter:
http://www.apmotorst...sr-102-076.html
That way you have a long(ish) run of nice big straight 102mm pipe where the intake air doesn't need to move as fast and the final part narrows (and accelerates the air) into the TB to maximise the intake efficiency.
#1868
Posted 12 April 2015 - 10:30 AM
#1869
Posted 12 April 2015 - 10:37 AM
#1870
Posted 12 April 2015 - 11:17 AM
#1871
Posted 12 April 2015 - 11:55 AM
I don't fancy that Plus my filter is due to be changed anywayI'll probably get shot down for this but how about do a power run without the air filter or fix a stocking over the end to keep out the big stuff. Should tell you pretty if its something other than the air filter restricting
#1872
Posted 12 April 2015 - 12:14 PM
Just fit a smaller pulley and be done with it. Your car is shockingly slow for a Harrop SC
#1873
Posted 12 April 2015 - 12:19 PM
Lol 🚙💨 But yet still as quick as yoursJust fit a smaller pulley and be done with it. Your car is shockingly slow for a Harrop SC
#1874
Posted 12 April 2015 - 12:21 PM
In a straight line! It should be with my lovely cheap stock engine!
#1875
Posted 12 April 2015 - 12:22 PM
Wouldent call amount of money you have spent cheap It scares you before pump was changed Or was that my driving that you were scared offIn a straight line! It should be with my lovely cheap stock engine!
#1876
Posted 12 April 2015 - 12:23 PM
Driving
#1877
Posted 12 April 2015 - 12:24 PM
LolDriving
#1879
Posted 13 April 2015 - 08:11 AM
good job and at least no one can say you haven't been trying
#1880
Posted 13 April 2015 - 10:34 AM
6 user(s) are reading this topic
Bing (2)
