Project Chill 1
4396 replies to this topic
#1941 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 28 April 2015 - 01:41 PM
Careful you don't suck in some dark matter and black holes :D
#1942 CHILL Gone DUTCH
Posted 28 April 2015 - 02:44 PM
As long as it isn't my restriction
#1943 smiley
Posted 28 April 2015 - 07:02 PM
In org tradition you need to put your penis in there :sleep:
#1944 CHILL Gone DUTCH
Posted 28 April 2015 - 07:21 PM
I did try but it didn't fit
#1945 CHILL Gone DUTCH
Posted 29 April 2015 - 04:32 PM
Got the air filter in
And it's big
It's actually to big to put the 125mm ducting in the ear
I'm thinking of a naca duct over the ear on start of wheel arch with a 125mm adapter or on the triangler piece where the fuel filler cap is on the other side
Any thoughts on best place to put it
& where to get a naca duct with a 5" round adapter piece on it
#1946 CHILL Gone DUTCH
Posted 29 April 2015 - 04:34 PM
Filter only just fits in It's that big I had to use the wheel arch to get it in
#1947 oakmere
oakmere
  • 2,143 posts
Posted 29 April 2015 - 09:46 PM
If it is sticking well into the ear I would not worry about the ducting I think it is only to stop warm air from the engine being drawn in. I would just try it as is before messing with ducting as you may just end up restricting flow. Do you still need the 90 degree adapter? If so I will drop it off tomorrow.
#1948 CHILL Gone DUTCH
Posted 29 April 2015 - 11:18 PM
Yes please Martin 👍
#1949 CHILL Gone DUTCH
Posted 02 May 2015 - 03:04 PM
Anybody used one of these
http://www.demon-twe...CsYHxoCJjLw_wcB
been thinking about a shift light for a wile now
#1950 CHILL Gone DUTCH
Posted 07 May 2015 - 08:04 PM
ok new filter is on
LS4 is on
fuel learning done
top end fueling done and AFR are good in the power runs
but still have a issue
my thoughts are boost leak or belt slip or maybe even its the car over coming a wall of  heat of some description
this dip will be the death of me
#1951 CHILL Gone DUTCH
Posted 07 May 2015 - 08:25 PM
sC cars love a cold night
#1952 Exmantaa
Posted 07 May 2015 - 08:45 PM
You're still on a 5-rib belt??
And did you alrready play with ignition timing in the dip? (cannot see any knock retard)
#1953 CHILL Gone DUTCH
Posted 07 May 2015 - 09:12 PM
There is very little knock No extra power is gained by putting more ignition in tried a extra 3 degrees and no change but does get knock It's been put to me it could be wheel spin so going to try a third gear run Problem is with that is the speed I will be going when I hit limiter So private long road required 😉
#1954 CHILL Gone DUTCH
Posted 07 May 2015 - 09:13 PM
Yes 5 rib But have tried 3 different makes
#1955 oakmere
oakmere
  • 2,143 posts
Posted 07 May 2015 - 09:42 PM
Can't see from that but no dip in boost it just keeps climbing.
#1956 CHILL Gone DUTCH
Posted 08 May 2015 - 09:29 AM
Yes boost keeps climbing
#1957 FLD
Posted 08 May 2015 - 10:13 AM
Looks like you'll be going for a toothed belt soon :lol:
#1958 CHILL Gone DUTCH
Posted 08 May 2015 - 10:19 AM
If belt was slipping I would be losing boost I'm not losing boost
#1959 Exmantaa
Posted 08 May 2015 - 10:20 AM
If your boost is consistent, can you see any strange things in wheel speed vs rpm's in the logs? (wheel/clutch slip...)
I think you had this dip in all your logs? Something head/cam/exhaust related?
#1960 CHILL Gone DUTCH
Posted 08 May 2015 - 10:39 AM
Will check some logs now Thanks for the pointer and idea
6 user(s) are reading this topic
0 members, 6 guests, 0 anonymous users
