Project Chill 1
#1961
Posted 08 May 2015 - 10:46 AM
#1962
nothing obvious
#1963
Posted 08 May 2015 - 12:30 PM
Edited by oakmere, 08 May 2015 - 12:31 PM.
#1964
Posted 08 May 2015 - 12:35 PM
#1965
Posted 08 May 2015 - 12:40 PM
#1966
Posted 08 May 2015 - 12:52 PM
Exhaust was changed so unlikely to be exhaust Nothing internal of engine has changed So head or cams is possible what do you Think it could be ??If your boost is consistent, can you see any strange things in wheel speed vs rpm's in the logs? (wheel/clutch slip...) I think you had this dip in all your logs? Something head/cam/exhaust related?There is very little knock No extra power is gained by putting more ignition in tried a extra 3 degrees and no change but does get knock It's been put to me it could be wheel spin so going to try a third gear run Problem is with that is the speed I will be going when I hit limiter So private long road required
#1967
Posted 08 May 2015 - 02:09 PM
#1968
Posted 08 May 2015 - 02:10 PM
That power run looks much worse than the one on the log you sent to me. It might be worth doing 4 or more runs to see what the graph looks like.
Alternatively due to your power levels a dyno run at somewhere like EFI Parts might be worth considering.
This one Martin
Think a trip to a dyno might be necessary soon
#1969
Posted 08 May 2015 - 02:16 PM
#1970
Posted 08 May 2015 - 02:18 PM
Edited by oakmere, 08 May 2015 - 02:20 PM.
#1971
Posted 08 May 2015 - 02:19 PM
#1972
Posted 08 May 2015 - 02:21 PM
which road martin
is there any houses there as ive been moved on for disturbing the peace a few times now
#1973
Posted 08 May 2015 - 02:48 PM
#1974
Posted 08 May 2015 - 02:51 PM
👌The A51 from the Tarvin roundabout. It is on a hill but you can do one run down one run up. As you head down the road it straightens up for the run. You can the turn at the junction and come back to the roundabout. The road isn't lined with houses.
#1975
Posted 09 May 2015 - 11:55 PM
nothing obvious
can you enlarge the 2 max rpm runs?
#1977
Posted 10 May 2015 - 05:32 AM
its consistently at 6000 rpm when power rather drops off or flattens out
#1978
Posted 10 May 2015 - 07:28 AM
