Wiper Blade!
Wiper Blade Windscreen
15 replies to this topic
#1 KevinB
KevinB
  • 51 posts
Posted 18 February 2013 - 10:33 AM
Hi, this may seem a little pointless but it's driving me crazy. My precious VX220 has a really unusual wiper blade arm. The arm does not have a hook on it, it is flat with a screw hole. Does anyone know where I can get a wiper to fit this arm? I'm happy to post a pic if required. Thanks K.
#2 Rusty789
Rusty789
    Ginger Ninja
  • 2,120 posts
Posted 18 February 2013 - 10:39 AM
I think I'm right in saying this is an earlier VX then? They changed the wiper arm at one point, or people converted to the elise S2 one...
http://www.elisepart...iper-arm-blade/
#3 KevinB
KevinB
  • 51 posts
Posted 18 February 2013 - 10:43 AM
Yes mate, 2001. I could do with keeping the cost down (seriously have a lot to do on it), can I get the wiper from anywhere? In brief I need to - service, MOT, Cam Belt, two new tyres, sort our an engine fault, replace the speakers and tax the car.
#4 Rusty789
Rusty789
    Ginger Ninja
  • 2,120 posts
Posted 18 February 2013 - 10:45 AM
You'd be able to get a wiper from somewhere, but I've never had to... Always had the hook arm type, I'm sure someone will come along and point you in the right direction shortly.
#5 Craig S
Craig S
    DA-DA-DUM!
  • 2,787 posts
Posted 18 February 2013 - 11:08 AM
Quick fix would be just a replacement blade (just the rubber bits) and use your original fitting. A stealer will charge you over £30 for a full replacement wiper, I stupidly asked a good few years back.
#6 D3YMO
D3YMO
    Scammer
  • 1,554 posts
  • Interests:Cars, Gym, Basketball, Football, LFC, Usual Stuff...
Posted 18 February 2013 - 11:14 AM
I have a Y reg and have the hook type...and looking through the recipts of the car it doesnt seem to have been replaced in its ownership - seems they were luck of the draw on 2001 models
#7 N.E.M.O
N.E.M.O
  • 792 posts
Posted 18 February 2013 - 11:28 AM
I have a 2001 and I had the same arm. I looked for a while and couldnt find a blade so I just replaced the arm with an Elise parts one in the end
#8 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 18 February 2013 - 11:34 AM
The EP arm and a cheap tesco blade is the same price as getting the funcky VX-ONLY-SPECIFIC-POINTLESSLY-OVER-ENGINEERED-AND-YET-STILL-UTTER-SHITE-WIPER-BLADE (VOSPOEAYSUSWB for short) from a stealership. thumbsup
#9 GiGo
GiGo
  • 5,657 posts
Posted 18 February 2013 - 11:47 AM
I've got my old arm if you want it? Its got the hook type connection on it, I replaced mine for a spay arm, PM me if your interested :)
#10 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 18 February 2013 - 12:56 PM
hi if its a 2001 I assume it is an NA no cam belt chain driven and not desperate unless its rattling in start up or noisey makers say good for 100 000 miles but I wouldn't risk it
#11 cosmicegg
cosmicegg
  • 103 posts
Posted 18 February 2013 - 01:28 PM
It's an Elise S1 wiper arm / part.
As mentioned, 3 courses of action, either:
Buy an Elise S1/Vx220 wiper blade
Or
For roughly the same cost, buy and Elise S2 wiper arm and fit a generic blade.
Or
Bodge job a new piece of rubber in.
If you go for option 2, the blade will be pennies to replace next time around.
Personally, both our cars have s2 arms on them.
#12 2GOOD
2GOOD
    Old Timer zzz...
  • 4,451 posts
Posted 18 February 2013 - 01:47 PM
Swapped my wiper arm for the later Elise/Exige arm & the lotus wiper blade. Didn't cost much more than the later type genuine Vauxhall blade on it's own! Vauxhall had changed the supplier, the blade was really poor & at £20+... Lotus arm & blade £25ish inch longer blade & does better job than original. Replacement lotus blade less than £10.
#13 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 18 February 2013 - 02:09 PM
i have the stupid s1 arm and just modded a normal blade to fit.. when it needs replasing again I will go for a s2 arm
#14 Claws
Claws
    Stage FA NA FTW!
  • 5,246 posts
  • Interests:Daft plastic cars
Posted 18 February 2013 - 02:22 PM
I bodged a standard blade on to mine, had to drill out the pin in the centre where the hook should attatch
#15 mark moyz
mark moyz
  • 643 posts
  • Interests:Redundancy demotions pay cuts 0 hours contracts employment shaftings
Posted 19 February 2013 - 10:56 PM
Asda are selling an aero wiper blade for about 7 quid and comes with about 8 different plastic attachments maybe this will fit ? my blade is usless so i will probably get one soon.
#16 judgefargo
judgefargo
  • 8 posts
  • Interests:Design, cars, motorbikes
Posted 13 September 2020 - 06:09 AM
Hi lads
Sorry for reviving an old thread, thought this info could be useful for some one else.
I was struggling also to find a replacement blade for my Speedster, as it uses the S1 system with pin, so checked the Elise forum and they use the following:
Bosch SP23
This blade has a hole that is exactly the same diameter as the S1 pin, then if needed you just slightly drill the centre pin of the Bosch blade (its like a rivet, so just a few spins and you can poke it through) and youre done.
I hope this helps someone else out also, I have done it on mine and works fine, bought on Amazon so there is availability.
Drive safe!
Also tagged with one or more of these keywords: Wiper Blade, Windscreen
