Fezzasus Heater
14 replies to this topic
#1 vocky
Posted 19 February 2013 - 03:43 PM
Just thought I would say what a great mod this is, even with the roof off and driving at 70mph you can still feel the heat from the heater :D
Around town (with the roof off) you hardly notice the outside temperature is just 7 degrees, no wonder those who run about with the roof on have to turn the heater down :blink:
If you are undecided about purchasing this heater my advice is buy it Imnotworthy
#2 MWS
MWS
  • 1,229 posts
    Cars - VX220s
    Basketball - Miami Heat
Posted 19 February 2013 - 03:50 PM
It is on my list of "wants", but can't buy anything off that list until my list of "needs" is empty :(
#3 JG
JG
  • 13,612 posts
Posted 19 February 2013 - 06:02 PM
Would you fill it with coolant after first install to avoid air pockets?
#4 Hark
Hark
  • 3,443 posts
Posted 19 February 2013 - 06:10 PM
Mine is being fitted tomorrow. :tt:
#5 Pidgeon
Pidgeon
  • 5,254 posts
Posted 19 February 2013 - 06:18 PM
Wow, perhaps NAs have a better coolant supply. Mine is still too cold at M'way speeds with the roof on.
#6 Stik
Stik
  • 174 posts
  • Interests:Cake
Posted 19 February 2013 - 09:41 PM
What's your coolant temperature like? Presumably that has a big effect on the temperature of the air coming from the vents
#7 fezzasus
Posted 19 February 2013 - 10:41 PM
That shouldn't be the case, if anything turbos tend to heat up quicker. Put the heater control on an intermediate setting, place your hand on the silver control valve and feel if it's clicking. If it isn't then the valve needs replacing - I have had at least two bad batches of valves.
#8 Gedi
Gedi
    404 Not Found
  • 5,547 posts
  • Interests:Nothing
Posted 19 February 2013 - 10:59 PM
Doesn't the turbo run about 10 degs cooler than the NA?
#9 fezzasus
Posted 20 February 2013 - 06:58 AM
Only if it has a cool running stat. It gets hotter quicker because iron rejects heat better than steel and its a higher power density engine. Also based on entirely empirical evidene, it gets hotter quicker.
#10 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 20 February 2013 - 08:14 AM
I take it you will still be making these in a year or two - as I will definitely put myself on the list if my purchase comes off.
#11 vocky
Posted 20 February 2013 - 08:18 AM
My car was running at 87 degrees yesterday and heater fan was on full speed, at 70mph with the roof off we still had warmth around our legs, not huge amounts (most of the heat was being sucked straight out of the open roof) but enough to fell comfortable.
#12 Kev S
Kev S
  • 608 posts
Posted 20 February 2013 - 09:09 AM
best I get mine fitted then it's not supplying much heat sat on the garage floor!
#13 Silent Steve
Silent Steve
    Tit
  • 2,000 posts
Posted 24 February 2013 - 09:58 AM
Agree with this.
My heater was always total rubbish. Popped in a Fezzasus unit and had to turn it down last night (-2c outside) after it had been running a while with the soft top on, as i was too hot.
Cracking modification, I reckon thumbsup; no point having a stage 9 superturbo if your windscreen is frosted up on the inside and you cannot see out, I say. Thanks also to Tom for his prompt assistance when it was needed.
#14 TubbyNorman
TubbyNorman
  • 561 posts
Posted 24 February 2013 - 09:51 PM
The car gets too hot now with the Fezzasus heater fitted ! Continually having to turn it down now to the mid point on the dial. Now I'll have to find something else to complain about. Still, you run a Vauxhall, what can you expect ? :unsure:
#15 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 26 February 2013 - 09:52 PM
Agreed - fitted mine today and it creates a nice flow of warm air with enough oomph to blow onto the screen AND onto your feet to warm the cabin up!. Another very happy customer here - well made bit of kit that wasn't as bad to fit as I was expecting. Thanks Tom thumbsup That's one job sorted, now I just need to get cracking on the other 10 (although the list seems to grow quicker than I can get through the jobs...)
