How Strong Is Tigerseal?
37 replies to this topic
#1 Bargi
Bargi
  • 4,483 posts
Posted 05 March 2013 - 08:42 PM
Need to reseal some headlights but would like to take them apart at a later date. Can I reheat tigerseal to break them apart or can someone recommend a different sealant that's more manageable. Cheers!
#2 Hark
Hark
  • 3,443 posts
Posted 05 March 2013 - 08:43 PM
Having had a rear light lense fall off on a very very hot track day I wang something that won't come apart. Lol
#3 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 05 March 2013 - 08:45 PM
I'd say it was just your poor DIY skills that caused that. ;)
#4 Kieran McC
Kieran McC
  • 3,416 posts
Posted 05 March 2013 - 08:50 PM
Cheers!
Tiger seal is a polyurethane sealant very strong and flexible try silicone sealant it will come apart easier.
#5 .Adam.
.Adam.
  • 405 posts
Posted 05 March 2013 - 08:53 PM
I've found Tigerseal/Sikaflex to be pretty strong, I used it to stick the cycle wings on my Westie, and they didn't fall off, although I never had a need to try and take them off, so can't say how easy or hard it would have been to unstick them.
#6 Nev
Tigerseal sets like rock, dont use it if you want to ever take it apart.
#7 darronwall
darronwall
  • 2,706 posts
Posted 05 March 2013 - 08:57 PM
black silicone.tigerseal will be a pig to get apart
#8 Zuber
Zuber
  • 1,429 posts
  • Interests:Finding a way to motivate myself to get fit. Anything Interesting.
Posted 05 March 2013 - 09:11 PM
Wasn't it Tiger Seal that was used to bond the lights in the first place ? Assuming it was, then it isn't 'that' good... This topic reminded me of those old adverts where they had a bloke hanging from various precarious locations held there by his overalls bonded in place or something.
#9 techieboy
Posted 05 March 2013 - 09:13 PM
Solvite. thumbsup
#10 VXBONE
VXBONE
  • 297 posts
Posted 05 March 2013 - 09:14 PM
tigerseal is intense,sets like stone,it cannot be reheated once cured,so you would have to cut through it carefully to remove lense in future, and dont get it on you mums carpet,they go MENTAL!!
#11 Hark
Hark
  • 3,443 posts
Posted 05 March 2013 - 09:44 PM
Oem light that hasn't been split before as far as I can tell. Not the first I don't think mate.
#12 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 05 March 2013 - 09:45 PM
Silicone will not do. If you get plenty of heat on the tiger seal it will come apart but really it should be viewed as permanent.
#13 darronwall
darronwall
  • 2,706 posts
Posted 05 March 2013 - 09:53 PM
will it not?? i think you are wrong
#14 chris_uk
Posted 05 March 2013 - 10:08 PM
tigerseal doesnt set rock hard, it dries like a hard rubber, but deffinatly not rock solid.
#15 VXBONE
VXBONE
  • 297 posts
Posted 05 March 2013 - 10:35 PM
its an expression, obvoiusly not stone,but its certainly not flexible
#16 Steelic
Steelic
  • 544 posts
Posted 05 March 2013 - 11:20 PM
Some has gone off in the nozzle on mine and it set like rubber and is flexible.
#17 VXBONE
VXBONE
  • 297 posts
Posted 05 March 2013 - 11:28 PM
well i got bored and filled a whole the size of a sideplate in the garage wall and now it is hardcore!
#18 Bargi
Bargi
  • 4,483 posts
Posted 06 March 2013 - 12:11 AM
Interesting, is this possibly where the original seal is made from? here
Would gasket sealant work or not set hard enough?
#19 techieboy
Posted 06 March 2013 - 12:21 AM
I had to use some butyl tape after the Tollboothgate incident as I refused to drill holes in my rear clam. Was sticky as hell and think there's still some on there but it doesn't set hard and I wouldn't want to chance it on the light lenses. Though I believe Elise Parts or Elise Shop sell it for attaching the separate lens covers on the S1's.
#20 Hark
Hark
  • 3,443 posts
Posted 06 March 2013 - 06:46 AM
What else can you use that will definitely not come apart? What have others used, as this mid gas been done many many times before.
