How Strong Is Tigerseal?
#21
Posted 06 March 2013 - 08:25 AM
#22
Posted 06 March 2013 - 09:09 AM
#23
Posted 06 March 2013 - 09:22 AM
#24
Posted 06 March 2013 - 10:34 AM
will it not?? i think you are wrong
Silicone will not do. If you get plenty of heat on the tiger seal it will come apart but really it should be viewed as permanent.
Silicone dries out especially with the extreme heat cycling you get. Its a sealing agent rather than a bonding agent after all. Silicone will stick lights but you run a big risk of them flying off at some point. The lights have a decent amount if peel force on them when you are going at speed. I know people have lost rears after using silicone.
#25
Posted 06 March 2013 - 10:57 AM
#26
#27
Posted 06 March 2013 - 11:13 AM
The key with any PU adhesive / sealant like tigerseal is getting good surface contact. Given the viscosity of it there is potential for it to sit on the surface without really bonding to it. This is why there is a primer used on screens, crashboxes etc. The primer is a low viscosity version of the PU adhesive which gets into any texture on the surface giving a good bond. Without the good surface prep there is the risk that lenses etc will come off especially if your slow applying it and the bead of adhesive gets chance to skin over. If you are just using the sealer make sure the two surfaces are immaculately clean and then dont hang about. Alternatively you can get primer from a screen fitter. I bought a bottle a few years back for about 20 quid.
I wouldn't be too confident in silicone as it has a high peel so doesn't have the same bonding characteristics as PU. If you wanted uber strong then acrylic or epoxy would do but as said before they are very rigid.
I've been told that Tiger Seal is the best thing to use to bond a JB spoiler to the rear clam, but now I'm worried i'll mess something up and end up with a right mess on my clam
Any tips on how to do this Matt?
#28
Posted 06 March 2013 - 11:21 AM
#29
Posted 06 March 2013 - 11:23 AM
#30
Posted 06 March 2013 - 11:25 AM
Edited by turboluca, 06 March 2013 - 11:26 AM.
#31
Posted 06 March 2013 - 11:35 AM
Use masking tape around where the spoiler will sit so if it does go beyond where you want it to be it should be on the tape. Wear gloves, if you get it on your hands its a case of letting it wear off! Have some acetone (not nail varnish remover) or gunwash handy along with a cloth. Whilst its not set you can remove it with solvent. If you have nail varnish remover it will have oils etc in it so will cause bonding broblems. Make sure the surfaces are dead clean. Its just some care with doing it. You should be fine.
Thanks Matt
#32
Posted 06 March 2013 - 11:54 AM
#33
Posted 06 March 2013 - 01:40 PM
Yes watched them on tv make a large tank just butting the glass edge up with silicone when dry they filled it full of water and two blokes pushed it off the table.it smashed to bits but not one bit of the silicone came away.we use it a lot and on the right stuff it is very strong.i stuck a metal plate to conti board with it and could not get it off even levering with big screwdrivers it was solid.I dont know much about sealants and adhesives but having kept some pretty large (200 gallon plus) fishtanks im suprised silicone is being questioned?
#34
Posted 06 March 2013 - 01:44 PM
Nay bother. If it helps I can pick up a tube of generic PU for you. Its about 4 quid a tube! I'll be off shopping friday or monday.
Ooh, get me a couple of tubes will you Matt?
#35
Posted 06 March 2013 - 02:20 PM
#36
Posted 06 March 2013 - 02:23 PM
#37
Posted 06 March 2013 - 02:37 PM
#38
Posted 06 March 2013 - 04:27 PM
