No, only one of from Jamie's car.
Scuffers - Can I assume the lap times you are posting are from Jamies TA car? How much cash has been poured into it to make it do that? 50K-60K? On the original subject, how much of that is on the arb? 1%?
Assides, thats not really the point is it?
If you want to get technical, its about cornering speeds, ie just how much grip you can get with optimised suspension.
I would love to get into a proper discussion with real track data to back this all up, but you may have noticed, there is none being offered for this rear ARB setup.
I am not the one suggesting anybody goes out and buys the most expensive option out there, quite the opposite.
Seems to me the problem is the vendor of the expensive option is not prepared to put up the track data to defend it.
PS. I also have some concerns about what its bolted to...
And trying to compare lap times x 10 posts was the point then?
Yes we know, it was mentioned right back at the start of the thread on SimonR's original post, but thanks for reminding us.
Using your posts on here as a reference, that would be quite pointless as already pointed you were incapable of calculating the rate for a rear ARB to the extent your final conclusion was to take it off. perhaps you could advise us of how you would interpret the data should it be supplied, exactly which would be interpolated and which used in isolation for the calculations? what formula would you use for which dynamics?
Or more likely would you just like the collected data handed to you on a plate?
interestingly CF doesn't either, check the posts, and on SELOC (assuming your banned status for being abusive has been relinquished). or whatever it was you were banned for because I I have little doubt you will want to split hairs over that as well.
On the basis this was not designed for a race car what would it matter anyway? The primary relevant data is what the customers think of it.
Now you need to be a little careful Simon, if you are suggesting in any shape or form there is a structural problem that could be close to libel.
