Edited by chris_uk, 15 March 2013 - 07:33 PM.
Which Arb?
#121
Posted 15 March 2013 - 07:33 PM
#122
Posted 15 March 2013 - 07:46 PM
#123
Posted 15 March 2013 - 07:52 PM
So, in one stroke, you have just written off the whole point in racing......scuffers... what are lap times going to prove?
Why else would you fit performance enhancements without them enhancing the car.
Edited by Scuffers, 15 March 2013 - 07:53 PM.
#124
Posted 15 March 2013 - 07:56 PM
#125
Posted 15 March 2013 - 07:57 PM
Edited by P11 COV, 15 March 2013 - 07:57 PM.
#126
Posted 15 March 2013 - 08:19 PM
Me thinks your not getting this....
how are your laptimes in a car compaired to someone elses car going to prove or disprove a mod? in this case an ARB
there are way too many variables to take into account, the only way this will be accomplished would be to have a single car, same driver etc and change just the arb's and set them up accordingly.. only then will you really be able to see which is better than another..
#127
Posted 15 March 2013 - 08:24 PM
Was going to say something but then couldn't be arsed.
#128
Posted 15 March 2013 - 09:08 PM
I'm still waiting for some real laptimes from the CF boys... (or are you hoping nobody will notice...?)
#129
Posted 15 March 2013 - 10:19 PM
#130
Posted 15 March 2013 - 10:55 PM
Surely the cheapest option is to do nothing at all …..
Indeed.
Setup/test drivers at Lotus like Dave Minter are arguably the best in the world at such things, so long as you are intending to drive the car on the factory intended road surfaces like "Joe Average" then you will be hard pressed to beat the basic factory setup. Though I understand the OP mainly drives his on track, so some changes may well be waranted.
There is a lot of common sense in what you say, but you have to remember that what a test driver would want to produce and what the lawyers, sales managers etc, want to see are not the same, nor should the accountants input be ignored. (This last point is very poignant).
The lawyers will want to see handling characteristics that are considered safe and very forgiving, (this alone hacks into the test drivers dreams) sales reps want to display the handling qualities but also the comfort, the accountants want it done with the cheapest possible components and so by the time the ideal becomes the reality it has been heavily compromised.
Unless you include computer controlled driving aids, stabilisation systems etc, to give the driver a higher level of controllability without allowing him to lose control you will always end up with a softer car than some would wish.
#131
Posted 15 March 2013 - 11:26 PM
"I had a girlfriend once, I sent her a love letter and she signed it and gave it to her other boyfriend"
"was that gotta do wiv me"
PEYEEWT
#132
Posted 16 March 2013 - 05:51 AM
So back to what's the point then?
Why spend money on something that people are not prepared to quantify?
Is Mike wasting his time trying to improve his car?
The very fact that nobody has ponied up any times kid of illustrates the point.
#133
Posted 16 March 2013 - 07:21 AM
#134
#135
Posted 16 March 2013 - 08:20 AM
With respect, that just makes it worse...Simon, it is not always about racing or fastest lap times.
The CF set up I drove on JGs car was lovely and is a great solution on a road car or those not so serious about tracking. If you are looking to focus on track stuff, the traditional route of stiffening the chassis through spring rates is the way forward IMHO.
I am totally unbiased on this subject BTW.
why in gods name do you need an (rear) ARB on a road car in the first place (you could actually argue the same for the front one, hence why the std item is so weedy)
Look, somebody needs to explain WHY you need a rear ARB on one in the first place.
I am the first person to admit running a (relatively) stiff ARB on a road car would be less than ideal, as all that will happen is you get bump-loads transferred across the car (why do you think we have independent suspension to start with?).
to then argue that a rear one is for road use is somewhat perverse? seems to me it's more about 'please come and spend some money with us' to me.
I (as have others) tried to run rear ARB's on track-race cars, and whilst it's not a black and white issue, to get one that's stiff enough to have any real effect is hard to start with, and once you are at that point, it's actually pretty unpleasant.
two main issues, as it loads up the loaded wheel, it unloads the other one, to the point that you now have zero grip/traction on the inside wheel, and as we all know (or dam well should), two tyres on the ground will always grip better than one.
second problem is that once you in a corner and the suspension had reached it steady state (relatively), if you then hit an bump with the inside wheel (like the apex kerb), that load is suddenly transferred across to the loaded wheel, which if it;s at anything like it's grip limit, is going to upset it, at which point, your going sideways, very suddenly.
Now, I agree, most purpose built race cars have rear ARB's, but please remember the Elise/VX platform was not designed like this, it's a road car with all the compromises that brings, like high COG etc.
Lastly, from what I have seen of a lot of rear ARB setups, they seem to all rely very much on bracing againstthe rear subframe, well, to my mind these are wobbly enough as they are, adding additional torsional loads to it is not going to help it's case, also a lot seem to use the top read wishbone to attach to, bad idea, as the only link this has to the uprights is the two plinth bolts, that are not designed/orientated to take vertical loads (and are fragile enough already - seen way too many fail on road/trackday cars when people do not keep a check on them).
in summary, uprating the front ARB to improve it;s track manners/performance is a no-brainer, there are several on the market, and broadly speaking, one makes 7/8" or 1" etc. bar will be very similar (in stiffness) to another.
Personally, for a road car and occasional trackday, a 7/8" one is probably sufficiently stiff to help without any real road car downsides.
Also, please remember that an ARB is very much a tuning device, and should not really be looked at as a substitute for springs/dampers, they all have to work together along with the tyres.
#136
Posted 16 March 2013 - 08:29 AM
#137
Posted 16 March 2013 - 08:58 AM
Edited by Firthy, 16 March 2013 - 09:01 AM.
#138
Posted 16 March 2013 - 09:15 AM
Edited by Bumblebee, 16 March 2013 - 09:18 AM.
#139
Posted 16 March 2013 - 09:33 AM
Im not saying that anyone is wasting time when trying to improve im just pointing out that you cant compare your laptimes against someone elses and then say the reason your faster is because of the arb setup. There are too many other factors like driver, power, weight, tyres etc to take into account.
Like ive already said, until you get 1 car, 1 driver and test it back to back with the different arb's your never going to answer to which is better. All your going to get is one mans opinion to another.
Edited by chris_uk, 16 March 2013 - 09:37 AM.
#140
Posted 16 March 2013 - 09:38 AM
