Coolant Flow Direction
6 replies to this topic
#1 TheHood
TheHood
  • 1,036 posts
Posted 12 March 2013 - 02:07 PM
Just after conformation - does the water flow go head, off side sill, rad, near side sill, oil cooler, engine? Need to fit a fan controller. Tar-very-mooch :) ETA it's the 2.2
Edited by TheHood, 12 March 2013 - 02:08 PM.
#2 techieboy
Posted 12 March 2013 - 02:19 PM
It does indeed. Like so:
#3 TheHood
TheHood
  • 1,036 posts
Posted 12 March 2013 - 02:28 PM
Why thank you sir thumbsup :)
#4 FLD
Posted 12 March 2013 - 03:19 PM
Is it me or is the thermostat at the wrong end of the rad circuit? (the diagram is right, the car is designed wrong!!)
#5 vocky
Posted 12 March 2013 - 04:27 PM
Apparently the thermostat is the inlet side for an alloy engine and cast iron blocks have them on the outlet :wacko:
Also helps with emissions :rolleyes:
But mine is on the outlet with the electric water pump set up :)
#6 FLD
Posted 12 March 2013 - 04:58 PM
Thats how I reckoned it should be. Guess there's people cleverer than I am that say it should be on the inlet. Perhaps winstar will be along to explain. :poke:
#7 oakmere
oakmere
  • 2,143 posts
Posted 12 March 2013 - 08:02 PM
Doesn't the heater circuit activate the thermostat? If not it would never open. Or do the thermostats have a small bypass to allow some flow?
