Sill Repair/replace Advice
76 replies to this topic
#21 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 21 April 2013 - 07:41 PM
Don't worry Matt, It won't be staying silver.
Good man. Decided already? Or up for an .org vote? :unsure:/>
1. Mangham54 - Candy Pink. :lol:
#22 CocoPops
CocoPops
  • 17,181 posts
Posted 21 April 2013 - 07:42 PM
Lotus Aubergine Purple thumbsup
#23 fezzasus
Lotus Aubergine Purple thumsbup
Bingo
#24 fezzasus
Although I'll happy consider an .org vote
#25 FLD
Posted 21 April 2013 - 07:43 PM
2. FLD - dysentry beige :mellow:
#26 CocoPops
CocoPops
  • 17,181 posts
Oh, lucky guess, but fair play! Can't wait to se that on a vx thumbsup
#27 chris_uk
Posted 21 April 2013 - 07:45 PM
Looks good. :)
#28 fezzasus
Posted 21 April 2013 - 07:47 PM
Oh, lucky guess, but fair play! Can't wait to se that on a vx thumbsup/>
Someone has already done it, http://www.vx220.org...40#entry1322839
But I would like to retain some satin silver, wheels, v, lights.. Not sure about the nasty windscreen surround.
#29 FLD
Posted 21 April 2013 - 07:52 PM
Just an idea for this one:
Lay up some flat sheet and cut it slightly shorter than the hole. Lay up a fresh layer and slot it up the hole (ooer) and pull it down inside the sill. The fresh glass should bond it to the sill. Then build up the outside. You might want some self tappers to pull the two together while it cures. Is this clear or am I rambling?
#30 fezzasus
Posted 21 April 2013 - 07:57 PM
That's along the lines of what I was going to do, but using some aluminium mesh rather than a layer. The layer might flex less which is a bonus at this point. So I'll probably go down that route.
Lets see how I get on next weekend.
#31 FLD
Posted 21 April 2013 - 08:01 PM
Good luck with it thumbsup
#32 fezzasus
Good luck with it thumbsup/>
Cheers, and thanks for the advice - good to know I'm on the right route.
#33 fezzasus
Posted 21 April 2013 - 08:02 PM
Btw, I might as well turn this into my official repair/respray thread. Guess how much I'll be doing myself?
#34 jules_s
jules_s
  • 15,275 posts
  • Interests:Plane spotting
Posted 21 April 2013 - 08:11 PM
Fairplay to you Imnotworthy I think the aluminium mesh I've got might be a bit too thin to be effective, I'm also still mulling it over in my mind as to the best method to actually get the mesh in ... Current thinking is to divide the area up into top, curve and bottom. I'm still not 100% certain as to what order to fit the 'strips' though; possibly start at the top and work down, although something tells me the curve is more important to get 'straight' and access to this bit is most important. Trial and error is coming I guess :)
Edited by jules_s, 21 April 2013 - 08:12 PM.
#35 fezzasus
Posted 21 April 2013 - 08:13 PM
Fairplay to you Imnotworthy/>
Trial and error is coming I guess :)/>
The mesh is very flexible, it just needs to be hold enough to keep its shape while you apply the matting.
You're right trying to get the shame right, but its not as difficult as you think, you can sand back and build o until you get it right.
Edited by fezzasus, 21 April 2013 - 08:14 PM.
#36 jules_s
jules_s
  • 15,275 posts
Posted 21 April 2013 - 08:17 PM
Oh I agree wholeheartedly And I'm thankful for the advice :) I'm working on the basis that getting it as close as I can isn't going to be a bad thing lol ;)
#37 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 21 April 2013 - 08:21 PM
Adding to this I was behind Stuwy on the Hayling island run and collected part of his bodywork as I came around the corner, so I have now fixed that.
:blush:
pleased it looks ok :mellow: now and your sill repair looks spot on..
Purple on a vx thumbsup
#38 fezzasus
Posted 21 April 2013 - 08:30 PM
:blush:/>
pleased it looks ok :mellow:/> now and your sill repair looks spot on..
Purple on a vx thumbsup/>
Honestly, I'd almost convinced myself beforehand to respray. That just made it certain.
#39 fezzasus
Posted 04 May 2013 - 08:44 PM
I've started the respray. Since I've only used rattle cans before I decided to 'get my eye in' with my hardtop. I've never been that happy with the finish of if because the previous finish was applied straight to the gelcoat without sorting out the ripples in it. So after a couple of days sanding and filling, it was ready for the paint.
Needs a final go over with some cutting compound, but i'm pretty happy with the result.
#40 Wreelybro
Wreelybro
  • 1,641 posts
    360 Gaming 10-Pin Bowling.
Posted 04 May 2013 - 08:56 PM
Getting there Tom although I'm getting flashbacks seeing sand and filler on silver clams!
