Sill Repair/replace Advice
76 replies to this topic
#41 fezzasus
Posted 04 May 2013 - 09:04 PM
5 KG resin, 5 KG chopped strand 12 brushes 5 KG filler 1 Dremel 1 orbital air sander 1 belt sander 2 x spray guns should be enough to sort out 12 years of neglect.. I hope Matty, you and I are ridding the world of silver cars, the flashbacks have got to be worth it.
#42 fezzasus
Posted 06 May 2013 - 01:34 PM
Another day, another body part.
#43 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 06 May 2013 - 01:49 PM
That looks fantastic. What sort of prep do you have to do before painting?
#44 fezzasus
Posted 06 May 2013 - 02:13 PM
Thanks.
I'll try to put a proper guide together as I progress, but this is what i'm doing at the moment.
1. Key the surface with 240 grit.
2. Inspect surface for damage (stone chips and small damage), fill, sand back with 240 grit.
3. 2 x coats of high build primer (using U-Pol P88 equal parts thinner)
4. 1 x guide coat (1 part primer, 1 part base coat, 6 parts thinner)
5. sand back guide coat with 400 grit to remove high spots.
6. Base coat (number of coats depends on colour, I can get away with two with this stuff)
7. Clear coat.
#45 CocoPops
CocoPops
  • 17,181 posts
Posted 06 May 2013 - 02:53 PM
Love the colour thumbsup
#46 Claws
Claws
    Stage FA NA FTW!
  • 5,246 posts
  • Interests:Daft plastic cars
Posted 06 May 2013 - 03:03 PM
:yeahthat: Looks amazing, can't wait to see the progress :D
Edited by Claws, 06 May 2013 - 03:03 PM.
#47 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 07 May 2013 - 11:03 AM
Nice one looks like you've got a decent finish there Tom. Where are you spraying? In a garage or outside? I have loads of questions, might be worth giving you a ring. :)
#48 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 07 May 2013 - 11:07 AM
So do you take the old paint off or just rough it up then primer over the old paint?
#49 fezzasus
Posted 07 May 2013 - 12:14 PM
Just rough the old paint with 240 grit. No point taking it back to the gelcoat, actually I would strongly recommend you don't do that as it's easier for paint to stick on paint than it is to stick on gelcoat.
#50 fezzasus
Posted 07 May 2013 - 12:16 PM
Just in the garden, since i'm using solvent based paint the drying time is about 10 -15 minutes so not much chance to get crap on it. Was considering spraying in one of these to reduce contamination further: http://direct.asda.c...default,pd.html
I'll be free tomorrow evening if you want to give me a call.
#51 TazN
TazN
  • 2,931 posts
Posted 07 May 2013 - 12:26 PM
5 KG resin,
5 KG chopped strand
12 brushes
5 KG filler
1 Dremel
1 belt sander
2 x spray guns
Tom what spray guns are you using? feed off an air compress?
#52 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 07 May 2013 - 12:29 PM
And where do you get the paint? At this point you will be regretting having teased us :lol: ...
#53 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 07 May 2013 - 01:02 PM
:wub: :wub: :wub: :wub: :wub: :wub: :wub: THAT COLOUR
#54 Bargi
Bargi
  • 4,483 posts
Posted 07 May 2013 - 01:24 PM
So you're pull off and replacing body panels 1 at a time from the car in the front yard, you're neighbours must be wondering what's going on :D
#55 fezzasus
Posted 07 May 2013 - 01:35 PM
It gets worse than that, yesterday I was spraying the bonnet in the garden with a face mask and shield on, but no shirt, while my retired neighbour dug his garden.
#56 fezzasus
Posted 07 May 2013 - 01:37 PM
ebay. Search P88 for the primer, high gloss cellulose for the clear. The base coat depends on what colour code you want - find the colour code and lots of places can make it up for you, these guys look promising http://www.paints4u.com/
#57 Wreelybro
Wreelybro
  • 1,641 posts
    360 Gaming 10-Pin Bowling.
Posted 07 May 2013 - 01:43 PM
Looking good Tom you in MK atm?
#58 fezzasus
Posted 07 May 2013 - 02:07 PM
Afraid not, this is all in Oxford.
#59 TazN
TazN
  • 2,931 posts
Posted 16 July 2013 - 03:41 PM
Any more sneak peaks on this Tom?
If I had somewhere to work no the car I'd be highly tempted to try my hand at it. If I mucked it up it would still need a respray so would only be down on the cost of the mats.
#60 rik
rik
  • 2,187 posts
Posted 16 July 2013 - 04:07 PM
regarding under the sill.. a technique I've used successfully before is to cut some strips of low gram fiberglass and laminate them on a flat surface and let them cure
Once they're dry peel them off the flat surface and they are strong enough to be inserted behind something and also weak enough to be able to be cut with scissors to the right shape
I would them coat them with some fast curing glue and insert behind the damage
Secure with self tapping screws if on a vertical or upside-down surface and/or use a temporary plate of metal/wood on the outside with a self tapper through the center to "pull" it into place if it's on a curve
Once its solidly in place drill some small holes in it to make sure whatever you fill over them with will stick properly
