Gb Now Active 10% Discount Eliseparts Front Anti Roll Bar 1" + 7/8
Posted 25 April 2013 - 07:55 AM
Posted 25 April 2013 - 08:12 AM
Posted 25 April 2013 - 08:30 AM
So if you want to put your name down, this is not a commitment to buy, just to collect numbers then it will progress from there.
Elise-parts products;
7/8" OD bar - https://www.elisepar...anti-roll-bars/
1" OD bar - https://www.elisepar...-anti-roll-bar/
1. siztenboots = 1" ARB
2. Bobby - 1" ARB.
Is there a huge amount of difference in real terms between the two?
Posted 25 April 2013 - 08:33 AM
If I knew the wall thickness of the tube and the dimensions I could give you an exact answer.
Posted 25 April 2013 - 08:37 AM
Yep, £72.
Posted 25 April 2013 - 08:41 AM
Posted 25 April 2013 - 08:52 AM
1. siztenboots - 1" ARB
2. Bobby - 1" ARB
3. D3YMO - 1" ARB
4.
Posted 25 April 2013 - 09:29 AM
Yep, £72.
iirc , the Mike Pilbeam formula, then stiffness increases with the diameter to a power of 4 , all other things equal
the £72 is because of the special racing red paint
Posted 25 April 2013 - 10:37 AM
2. Bobby - 1" ARB
3. D3YMO - 1" ARB
4. Gedi - unsure on thickness
Posted 25 April 2013 - 11:12 AM
2. Bobby - 1" ARB
3. D3YMO - 1" ARB
4. Gedi - unsure on thickness. 1" Gedi, trust me on that.
Posted 25 April 2013 - 11:43 AM
2. Bobby - 1" ARB
3. D3YMO - 1" ARB
5. TazN - unsure on thickness
I was going to go for 7/8" but now you've confused me Mike! <- do not turn into into another which arb thread
Posted 25 April 2013 - 12:34 PM
Posted 25 April 2013 - 04:02 PM
Edited by TazN, 25 April 2013 - 04:02 PM.
Posted 25 April 2013 - 04:18 PM
Posted 25 April 2013 - 05:29 PM
Posted 25 April 2013 - 08:26 PM
Could you just fit one of these bars with little adjustment on other suspension parts?
Fit the 7/8" to a standard set up Billies if you want. Will just be an adjustable standard one. Still a very worthwhile mod for track assuming you want to go stiffer for dry and softer for wet.
Posted 25 April 2013 - 08:27 PM
I'am right in thinking the adjustable 7/8 allows for a stiffer setup over oem though?
Yes as you can change the point of pickup for the drop links.
Posted 25 April 2013 - 09:01 PM
Posted 26 April 2013 - 10:21 AM
The 7/8 is not an upgrade on thickness over standard, it is only 5 point adjustable the 1" is thicker and adjustable.
7/8 = 22.2mm . The standard bar is 19 mm isn't it ??
Posted 26 April 2013 - 10:23 AM
2. Bobby - 1" ARB
3. D3YMO - 1" ARB
6. 2-20 - 7/8" ARB
