Having built up confidence with my silicone gun when fixing the pedal box into place, (and the fact that I'm currently doing a house renovation so silicone and decorators caulk is becoming second nature), I decided that it was time to tackle the windscreen frame.
Here it is hanging in the spray booth getting 3 coats of satin black along with 2 final coats of satin lacquer
This was the thing I was most worried about on the entire build. It's part of the main structure in case of the car rolling, so I had that aspect to worry about. Added to the fact that you only really get one shot once it's glued into place, it was definitely not a relaxed job
There's no record of anyone having tackled this on the forums, so armed with just this doc and my silicone gun skills, I got on with it
http://www.speedster...me, Replace.pdf
First I bonded the scuttle panel into place, it bonds to the chassis and the underside of the windscreen frame and acts as a seal between the front end and the cabin.
I forgot to get a pic, but it's the thing with the lotus sticker on it in this picture
I then did about 10 dry runs of fitting the windscreen frame, making sure that I could lift the screen into place slowly and carefully without it fouling anything, and making sure it ended up in the perfect position. I tried lots of different angles and when I was finally happy I made a start. First I cleaned off the entire bonding area on the chassis using the Dinitrol cleaning solution. I then applied the primer and once dry I applied the the adhesive. Taking pics was the last thing on my mind at this point.
I then slowly moved the frame into place, made sure it was positioned perfectly and used a ratchet and strap to tightly hold it in place while the adhesive went off.
Pics time, more Dinitrol
Held into place with the strap
As long as it was oozing out of the sides, I knew I'd applied enough adhesive. There was a more oozing out on the insides than the oursides, so I was pleased with that as it kept things neat(ish) and I didn't need to trim things afterwards.
You can see the strap mark on this pic.
And finally I made sure it was well sealed around the bodywork so no moisture could get in
