#21
Posted 30 April 2013 - 08:15 PM
#22
Posted 30 April 2013 - 09:09 PM
Because that's what the dumbfuckski diagnostics computer suggests it absolutely positively has to be (ask Smiley
). As suggested the "loom of doom" would be my first port of call. It's 99.98% certain that a new ECU isn't required, that's for sure.
STAY AWAY FROM VAUXHALL WITH ANY THROTTLE RELATED ISSUE.
Get the code(s) read, post them here and we will sort you out.
Edited by smiley, 30 April 2013 - 09:09 PM.
#23
Posted 30 April 2013 - 09:12 PM
#24
Posted 30 April 2013 - 09:43 PM
Arse or wallet Smiley?
You sure you actually went to Vauxhall?!!
Don't want to confuse people here to much. Their both muppet factories.
edit: here for shock value. STAY AWAY FROM THEM. SERIOUSLY, STAY AWAY.
Edited by smiley, 30 April 2013 - 09:57 PM.
#25
Posted 01 May 2013 - 06:52 AM
#26
Posted 01 May 2013 - 07:06 AM
#27
Posted 01 May 2013 - 11:08 AM
Jesus H Christ... €2k and if I remember correctly that didn't even fix the underlying failt did it?
I did not have the issue after that "fix", but by now i know that contactspray would probably have done the job.
This was the present i got when i picked up the car from them after 2k of repairwork:
#28
Posted 01 May 2013 - 11:11 AM
#29
Posted 01 May 2013 - 11:42 AM
#30
Posted 01 May 2013 - 11:54 AM
How did it end up with them? Did they pay for that?
yes.
Edited by smiley, 01 May 2013 - 11:54 AM.
#31
Posted 01 May 2013 - 12:55 PM
Do you have a code reader? If not I am in MK and you could borrow mine to find out.
Some might suggest TMS in MK but my experience is that they will just say the same as Vxl. When I had a misfire I paid £8o to be told it could be MAF, coil pack or ECU. Wasn't the most helpful result as I already knew that!
Cheers for the offer. Hockey is going to come and have a look this weekend. I might have another go at cleaning the contacts tomorrow. Last time i didn't take them fully apart (yellow bits off)
#32
Posted 06 May 2013 - 11:47 AM
#33
Posted 06 May 2013 - 11:53 AM
#34
Posted 10 May 2013 - 08:07 PM
#35
Posted 10 May 2013 - 09:06 PM
Doh!It's 99.98% certain that a new ECU isn't required, that's for sure.
#36
Posted 10 May 2013 - 09:18 PM
.org to the rescue I love this forum
#37
Posted 10 May 2013 - 09:20 PM
#38
Posted 10 May 2013 - 09:59 PM
What? I allowed for the 0.02% of instances, when that was the real problem.
#39
Posted 10 May 2013 - 10:11 PM
I'll drink to that.org to the rescue
I love this forum
#40
Posted 11 May 2013 - 08:49 AM
for future reference purposes.......
this is the second time I have seen this exact same problem;
the ecu pins in the four row ECU plug socket were corroded and broken off from the ECU itself, this meant they were corroded inside the engine loom plug, so we had to replace six wires in the loom plug to repair the engine loom. Then we simply swapped the ECU, immobiliser transponder (around the steering lock) and the immobiliser chips inside the two keys.
ps: glad to help a fellow owner ........ by removing the hard top and fitting the soft top ready for summer
Also tagged with one or more of these keywords: ECU, throttle
General Discussion →
VX220 Discussion →
Replacing The Ecu And Having IssuesStarted by den7 , 29 Feb 2020 ![]() |
VX220 Discussion →
Turbo Newbee Questions, Mapping Back To Original From Stage 1Started by Soren , 31 Jul 2019 ![]() |
VX220 Discussion →
Z22Se Ecu RequiredStarted by Sutol , 24 Jul 2019 ![]() |
Tuning & Modifications →
Vx220 Ecu BinaryStarted by positive_ , 30 Aug 2018 ![]() |
VX220 Discussion →
Opel Speedster Turbo Z20LehStarted by mementaurum , 15 May 2017 ![]() |
