![Photo](http://www.vx220.org.uk/forums/uploads/profile/photo-thumb-13087.jpg?_r=1350844185)
2.2 Engine Plates
#81
Posted 29 June 2013 - 09:24 PM
should be fine with the heat and plenty strong"
I was gonna try this............
http://www.ebay.co.u...e-/200732404986
It's black, heat resistant (unless your engine is on really on fire) flexible, and easy to get off if you need to. Not sure tigerseal would do the job?
#82
Posted 29 June 2013 - 09:48 PM
I finally lost mine today. The first time i had it stuck down with tiger seal but after a track day it came off with the heat but was lucky enough for it to sitting next to the fuel rail. So i stuck back on with some more heat resistance stuff and its came off again today and its nowhere to be seen.
RIP
#83
Posted 29 June 2013 - 10:05 PM
#84
Posted 29 June 2013 - 10:20 PM
#85
Posted 11 July 2013 - 07:06 PM
Hi, Put me down for VX220 engine plate if you have any left. I have also asked for a water expansion cover, you can post both together. Advise payment details.
Cheers...........Bob
#86
Posted 14 July 2013 - 09:22 PM
Any update on if you got this and if it worked...? Thanks Paul"i'd probably go for a bit of tigerseal
#87
Posted 15 July 2013 - 10:09 AM
pm sent
#88
Posted 01 August 2013 - 11:54 AM
Did we come to a consensus on how best to stick this on?
I presume to fit I need to unbolt everything off the top and it slips underneath?
#89
Posted 03 August 2013 - 10:55 PM
#90
Posted 03 August 2013 - 11:01 PM
I just put mine on last night with some evo stick impact, see how that goes, good for 100 degrees apparently will give the car a run and check to see how its doing
#91
Posted 04 August 2013 - 09:49 AM
#92
Posted 04 August 2013 - 10:14 AM
#93
Posted 04 August 2013 - 10:40 AM
That's what I am going to use when I get my plate.
#94
Posted 04 August 2013 - 10:50 AM
I guarantee you'll be checking its still there every time you drive itTook the car out for an hour this morning and its still attached :-)
![:D](http://www.vx220.org.uk/forums/public/style_emoticons/default/biggrin.png)
#95
Posted 04 August 2013 - 04:54 PM
I know, will have a little peer in through the grille every time! But it will be added to the list of things I check every time as I am so precious about my VX lol
#96
Posted 04 August 2013 - 10:34 PM
well I can vouch for the 3M body panel stuff as mines been on for over a year
