Ok, so here's the plan.
Coffee tables can't be tall, and seeing as it's going in a little wooden house this one can't be heavy. It currently weighs about a ton.
Here's the engine from the side with some labeling I've added.
For a coffee table I'm interested in the cyclinders and the crankcase, and that will give me a height of 48cm, which is only 3cm more than my current table. Engine diameter is 125cm - which is pretty ideal for what I want. Just as well as getting the larger 18 cylinder Centaurus would've been nigh on impossible!
So what I need to do is dissmantle the front - the prop reduction gear and the sleeve crank drive gears. I also need to dismantle the rear - the magneto's and the supercharger. I've already removed the carb (which was enormous).
However, this gives me a problem - how do I dismantle the rear of the engine when the engine mounts are there?
My plan is to remove the cylinder barrels first, and then make a temporary mount to hold the engine from where the cylinder barrels are bolted on. Then I'll have access to both ends of the engine. The barrels themselves will need treating/painting as all the steel bolts are badly corroded and the aluminium itself looks rough and industrial. Anyone have any tips of a good finish? All suggestions gratefully received.
With all that removed it should be a lot lighter, but still bloody heavy. So the next thing would be to remove the internals. Here's a picture of what they look like on another engine.
I think they're stunning to look at, even though in this picture you can't even see the crank and rods. These are the crank and rods from a Bristol Centaurus which is a similar engine, just with 18 cylinders.
So I'm thinking to re-assemble these from the supercharger forwards and make what would effectively be a glass crankcase so you can see it all, and make a dining table with it.
