#21
Posted 07 May 2013 - 07:18 AM
#22
Posted 07 May 2013 - 07:21 AM
#23
Posted 07 May 2013 - 07:30 AM
#25
Posted 07 May 2013 - 09:10 AM
#26
Posted 07 May 2013 - 09:14 AM
#29
Posted 07 May 2013 - 12:56 PM
#30
Posted 07 May 2013 - 12:58 PM
Edited by anz3001, 07 May 2013 - 12:59 PM.
#32
Posted 07 May 2013 - 01:27 PM
#33
Posted 07 May 2013 - 03:59 PM
'siztenboots', on 07 May 2013 - 1:27 PM, said:
try that with a triple reinforced sidewall R888
if youre a gambling man and youve got access to one, you can name your stake
If one 235 fits, they'll all fit. It purely boils down to the machine and the fitter from there. That machine was purchased so we can fit runflats, which we do with ease. there is noway a 888 has a stiffer sidewall than a RFT
#34
Posted 07 May 2013 - 04:08 PM
#35
Posted 07 May 2013 - 04:12 PM
#36
Posted 07 May 2013 - 04:34 PM
'anz3001', on 07 May 2013 - 1:02 PM, said:
Oh I just give up. Fek wheels and there numbers, offsets that, J this, triple reinforced that, profile this, ET that.. WTF is ET anyway!... I have read nearly every wheel topic since the beginning of time on .org and I still don't get it! What is the widest 17" front wheels I can get on the VX without issues with normal tyres that are not silly low profile ones? I'm so lost
'Stuwy', on 07 May 2013 - 12:56 PM, said:
Its actually not a measurement at all, its the type of rim
does the "J" just mean inches?
#37
Posted 07 May 2013 - 07:16 PM
'siztenboots', on 07 May 2013 - 4:08 PM, said:
just saying from personal experience and many others on here , there comes a point where even 160psi and the bead still won't pop on that you have to say , we give up. That was a 235/40/17 on to a Team Dynamics PR1.2 7.5J wheel , the same tyre fitted no problem on a 9J same.
Ahhh to be fair I was thinking more physically fitting as opposed to seating of the bead.
That really comes down to abit of perserverance and little things that a lot of fitters tend to forget. I go spare if a tech comes to me asking for help seating a bead and when I get there they havent removed the valve core! lots of fitting paste (or even penertrating oil) on the rim 'humps' as well as the tyre bead. and thirdly plumb it straight to the compressor, a pcl type gauge slows the air going into the tyre alot. Ofcourse you then dont know what pressure you are putting in there but you get used to timing it after youve done it lord knows how many times and ive never had a tyre explode on me to this day
#38
Posted 07 May 2013 - 07:24 PM
its a guess but if i was going to try id be considering a 7X17 with a 205/45X17 tyre initially but then ive got feck all experience with changing the sizes on a vx
#39
Posted 08 May 2013 - 12:59 AM
] Oh I just give up. Fek wheels and there numbers, offsets that, J this, triple reinforced that, profile this, ET that.. WTF is ET anyway!... I have read nearly every wheel topic since the beginning of time on .org and I still don't get it! What is the widest 17" front wheels I can get on the VX without issues with normal tyres that are not silly low profile ones? :(/> I'm so lost
Ha! That makes two of us then, I try to make sense of it but no, it's still gibberish.
#40
Posted 10 May 2013 - 10:54 AM
Just a quick update went to the car this morning and the "necks" of both valves have perished at the same time! So basically I got to my car and had two flat front tyres and when I put air in, it comes out at almost the same rate from the holes!
I have opted for the Eagle F1s (fitted £100 arriving Tuesday), the next best quote as I had to go local was £107 fitted, one could be with me in two days and the other would be there sometime before the end of the month! A fat lot of good that quote was.
KevinB.
Also tagged with one or more of these keywords: tyres, expensive, cheap
General Discussion →
VX220 Discussion →
New TyresStarted by Soren , 13 Mar 2019 tyres |
The Market Place →
Car Parts For Sale →
Team Dynamic 17 /18†Wheels With Yokohama Ad08RStarted by JohnnyVX220 , 08 Sep 2018 wheels, team dynamic, tyres |
VX220 Discussion →
Rear Tyres - Oem Part Number Doesn't Seem To ExistStarted by DJ_SL , 15 Jul 2018 tyres, parts |
Tuning & Modifications →
Improving The BalanceStarted by Munching Mike , 17 Mar 2018 handling balance, tyres |
The Market Place →
Cars For Sale →
Vx220 Na - Cat D - Cosmetic Front Clam - 53,000K - £5,900Started by London25 , 07 Dec 2016 cat d, for sale, project |
