I Could Cry.....
#41
Posted 08 May 2013 - 10:35 AM
#42
Posted 08 May 2013 - 10:46 AM
don't forget to replace both chain kits, the balancer chain tensioners are nearly always seized these days
Might also be worth replacing the alternator belt tensioner, alt belt and the rubber engine mount
Yes for the cost of them bits its a no brainer to put on new while they are off. The alternator belt tensioner will fall in half when you take it off anyway
#43
Posted 08 May 2013 - 11:03 AM
#44
Posted 08 May 2013 - 11:14 AM
or explode in your faceThe alternator belt tensioner will fall in half when you take it off anyway
unless its had a new one on.
the internal spring is fecking huge
#45
Posted 08 May 2013 - 11:21 AM
Edited by FLD, 08 May 2013 - 11:21 AM.
#46
Posted 08 May 2013 - 12:09 PM
#47
Posted 08 May 2013 - 12:16 PM
Oh my that's alot for the collars to be changed! Makes replacing with something else look the better buy. Glad I never bothered with mine now.
I should have looked at an upgrade. I think a basic set of Gaz's are £400 approx. Better when selling too. Hey Ho
#48
Posted 08 May 2013 - 12:26 PM
#49
Posted 08 May 2013 - 12:42 PM
#50
Posted 08 May 2013 - 12:43 PM
As you say it's done, not much you can do about that.
Lets get you all sorted out ready for one of the meets where I'll buy you a drink to cheer you up abit
I think I'll be buying a lot of beers fella.
#51
Posted 08 May 2013 - 01:58 PM
#52
Posted 09 May 2013 - 06:54 PM
I drove around for about 18 month with a chain noise until I realized what it was and got round to changing it, it may or may not snap soon.
#53
Posted 09 May 2013 - 07:57 PM
I have an old scabby but working hub if you want it.
#54
Posted 10 May 2013 - 09:39 AM
Has the car been mapped? Mine had a rattle sound at them revs under load after the CS map. Since installing the OBD Tuner the sound has gone. I also get transmission rattle at in that range and always have. I have both original tensioners in working order you can have. I don't think it is a cam chain issue as these are normally very loud at idle. If you remove the rocker cover (a 10 min job) the cam chain can be inspected to see if it has become loose.Update: If it's not a simple wire issue, I am gonna blow the remains of the budget on the hub so I can MoT it at the weekend. They have given me a decent price which I have run past a .org member that had recently done his and he agreed. Leaving me with a chain replacement. This will give me two options: 1. To try and borrow the extra cash and get a certain .org member to fit it. 2. To get the boys round and go for it. I don't think that the chain is about to fail (famous last words) and TBH I think that it is most likely a tensioner that has part seized? Would this account for the fact that the tapping is only between 1500-2200 revs under load. Out side of this range its very quiet. Running the engine up to high revs out of gear also produces no obvious tapping noise.
#55
Posted 11 May 2013 - 12:36 PM
The car hasn't been mapped no. It's definitely a tapping more than a rattle coming from the chain end.
The car passed the MoT today so it's just the chains that need addressing now. I really need to nail down the specific problem though. I'll take a look at the chain as you suggest though.
Thanks for the advice.
#56
Posted 12 May 2013 - 07:16 PM
How far should I be able to compress the chain at the top with the rocker cover off? I presume some amount of movement is to be expected?
#57
Posted 12 May 2013 - 07:58 PM
#58
Posted 15 May 2013 - 01:05 PM
Took the time to read through and printed off a couple of guides from z22se.co.uk on changing chains etc last night.
This one in particular was really good http://www.z22se.co....m-chains.10042/
Lots of really good pics
Have any of you guys used a specific one that you would recommend?
Edited by wanabee, 15 May 2013 - 01:06 PM.
#59
Posted 19 May 2013 - 05:19 AM
hi,my chain was replaced by the seller at a cost of £600...or so he told me,that was at vauxhall in newbury.
#60
Posted 19 May 2013 - 02:28 PM
Vocky says OEM genuine GM chain kit.. Auto vaux or LMF vauxhall or somewhere should be able to get you one for a descent prise..
