you could compare the angle of the chamfer against the original part, or it might just need tightening some more ?
Brake Pipe Replacement Guide
Started by
mqm
, May 14 2013 01:06 PM
42 replies to this topic
#41
Posted 19 June 2018 - 06:57 AM
#42
Posted 19 June 2018 - 07:37 PM
is a universal flair so will seal fine once tightened up
did you get lines with heat wrap on them for sill section?
#43
Posted 19 June 2018 - 10:04 PM
Hi
Yes will just have to see when bleeding it all.
I didn't get them with heat shield because that wasn't an option on the custom hose form but I will add some of my own down the sill. Clutch one is the kit with the heat shield on it. Found that clutch hose could do with another 5-10cm. Also 3d printed some clips to stop things flapping around. Will let you know the spec for the full length ones when it's all done so you could add those as a kit too if you wanted
