First Ever Overheat. Heeeelllppp!
Posted 17 May 2013 - 10:09 PM
Posted 17 May 2013 - 10:12 PM
Posted 17 May 2013 - 10:15 PM
Posted 17 May 2013 - 10:19 PM
Cheers Co-Co. Just a little unnerving. That "hot engine smell" spells "danger Will Robinson" to me! Anyone had any joy with a manual fan switch in the cabin? When I modded 4x4's, we'd whack in 2nd fans or fan upgrades... Anyone done this / worth doing? Ta. Ben.106 is standard for fan kick in. Nowt wrong from what you've said.
Posted 17 May 2013 - 10:21 PM
Tried that Kenni. I got the upgraded silicone heater mod in mine, so (theoretically) heater woks... But made FA difference!Stuck in traffic, i usually do my bit to help the engine cool is by turning the hot air on full inside. (Yes my hot air heater works
Posted 17 May 2013 - 10:25 PM
You can turn the fan off/on with a scangaugeCheers Co-Co. Just a little unnerving. That "hot engine smell" spells "danger Will Robinson" to me! Anyone had any joy with a manual fan switch in the cabin? When I modded 4x4's, we'd whack in 2nd fans or fan upgrades... Anyone done this / worth doing? Ta. Ben.106 is standard for fan kick in. Nowt wrong from what you've said.
Posted 17 May 2013 - 10:39 PM
Shame you can't do same with Dash Command (unless anyone know different).You can turn the fan off/on with a scangaugeCheers Co-Co. Just a little unnerving. That "hot engine smell" spells "danger Will Robinson" to me! Anyone had any joy with a manual fan switch in the cabin? When I modded 4x4's, we'd whack in 2nd fans or fan upgrades... Anyone done this / worth doing? Ta. Ben.106 is standard for fan kick in. Nowt wrong from what you've said.
Posted 17 May 2013 - 11:14 PM
Fit a manual fan switch if you're worried. (=> Search)
Posted 17 May 2013 - 11:15 PM
Posted 17 May 2013 - 11:44 PM
Worth doing in my opinion....a few guides on here, but I followed this one:
http://www.vx220.org...8-fan-override/
Posted 18 May 2013 - 12:34 AM
Your cars fine mate, I had a similar issue last year on the m62 fan kicked in at 106 engine smelled hot etc,
think that was a 2hr jam from memory, mine was the same never went above 89c.
Posted 18 May 2013 - 07:48 AM
Posted 18 May 2013 - 07:51 AM
Probably worse to pull over and switch off at 106 as the temp will rise a bit immediately after switching the engine off!
Posted 18 May 2013 - 08:00 AM
Posted 18 May 2013 - 08:08 AM
YeahthatProbably worse to pull over and switch off at 106 as the temp will rise a bit immediately after switching the engine off!
Posted 18 May 2013 - 08:57 AM
Or a pikey style switch, if you're that paranoid.Costs next to nothing.
Wow, dutch minds think alike.
H1WK, I shall defo be down e fan switch mod. A most excellent link. Thank you. Ben.Worth doing in my opinion....a few guides on here, but I followed this one:
Posted 18 May 2013 - 09:01 AM
Kind of figured that. Pulled over (engine running) popped bonnet and engine bay, cooled a little, shut off at 92 & allowed to cool further.YeahthatProbably worse to pull over and switch off at 106 as the temp will rise a bit immediately after switching the engine off!
Posted 18 May 2013 - 09:14 AM
Also tagged with one or more of these keywords: coolingexpansion tank, overheat, engine temp, hoses, pump, thermostat, radiator, na
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
The Market Place →
Car Parts Wanted →
2002 Vx220 - 2.2 - Need Abs Pump - Northern IrelandStarted by mpet72 , 03 Nov 2020 ![]() |
Welcome to VX220.org.uk →
Introduce Yourself - Newbies & Forum Guide →
Hello From Leamington SpaStarted by Jordang , 22 Aug 2020 ![]() |
The Market Place →
Car Parts Wanted →
Na HeadlightsStarted by jdscott , 02 Aug 2020 ![]() |
General Discussion →
Tuning & Modifications →
Bizarre Acceleration IssueStarted by MattMacc123 , 10 Aug 2019 ![]() |
