First Ever Overheat. Heeeelllppp!
#21
Posted 18 May 2013 - 09:18 AM
#22
Posted 18 May 2013 - 01:15 PM
#23
Posted 18 May 2013 - 01:37 PM
http://www.vx220.org...8-fan-override/
#24
Posted 18 May 2013 - 01:42 PM
Exactly, its a hot running design
Still baffles me why people seem to panic so much with a VX and temperature - ok so the majority of other cars have a gauge and not a number, but every car I have owned will happily sit showing between 100-115 degrees on the gauge all day long.
The fact that it's a pressurised system and is supposed to run over 100 degrees seems to slip peoples minds.
#25
Posted 18 May 2013 - 02:00 PM
Fair point Boombang. My bewilderment arose as first time I've hit these temps & (as previous) the smell of a baking engine is - generally - cause for slight concern. I know now (thanks to you guys). Still doing manual fan switch mod though! Ben :-)Still baffles me why people seem to panic so much with a VX and temperature - ok so the majority of other cars have a gauge and not a number, but every car I have owned will happily sit showing between 100-115 degrees on the gauge all day long. The fact that it's a pressurised system and is supposed to run over 100 degrees seems to slip peoples minds.Exactly, its a hot running design
Edited by Benzola, 18 May 2013 - 02:02 PM.
#26
Posted 18 May 2013 - 02:11 PM
What you might just be smelling is a slightly weepy rad and/or leaky bleed nipple.
My second VX always had a hot engine smell, after a few months found the rad was weeping and had it replace.
#27
Posted 18 May 2013 - 02:14 PM
#28
Posted 18 May 2013 - 02:22 PM
Level raising was more like a high pressure torrent of magma! Expansion went from 1/3 to over 1/2 full in a couple of seconds. Best route for clearing trapped air?You may have some air trapped in the system somewhere. Hence the level raising when you release the pressure.
Edited by Benzola, 18 May 2013 - 02:22 PM.
#29
Posted 18 May 2013 - 02:23 PM
Worthy point. Will investigate.What you might just be smelling is a slightly weepy rad and/or leaky bleed nipple. My second VX always had a hot engine smell, after a few months found the rad was weeping and had it replace.
#30
Posted 18 May 2013 - 02:25 PM
Passenger side in the front. Use the bleed valve on the hose that goes to radiator.Level raising was more like a high pressure torrent of magma! Expansion went from 1/3 to over 1/2 full in a couple of seconds. Best route for clearing trapped air?You may have some air trapped in the system somewhere. Hence the level raising when you release the pressure.
#31
Posted 18 May 2013 - 02:32 PM
Sound advise! Cheers Goose. Hot or cold before bleed (I'm assuming hot). Ben.Passenger side in the front. Use the bleed valve on the hose that goes to radiator.Level raising was more like a high pressure torrent of magma! Expansion went from 1/3 to over 1/2 full in a couple of seconds. Best route for clearing trapped air?You may have some air trapped in the system somewhere. Hence the level raising when you release the pressure.
#32
Posted 18 May 2013 - 11:25 PM
I have an 2.2 Zafira B, so basically a similar engine as the vx220. There is NO temperature gauge anywhere on the dash to indicate how hot its running, could be running at 101c all day every day for all i know. So if you dont see it you wont think about it.
#33
Posted 19 May 2013 - 05:30 AM
The car will sort itself out the only weak point is the rads dont really function ideally with been sat flat hence the issues with hotspots/leaks (on both ali and oem rads) The OEM bleed nipple is probably responsible for more problems than rads!
#34
Posted 19 May 2013 - 10:34 AM
I had a rad blow so fitted a switch for peace of mind, very rarely use it but its nice to know its there if stuck in standing traffic for too long. I get the same hot coolant smell too.
#35
Posted 19 May 2013 - 01:40 PM
Ok. So I just attempted to bleed the system. Bled from both nipples in engine bay... Fine... But when bleeding from radiator nipple... Nowt! Was expecting a satisfying hiss, followed by a "squirt" of coolant... But dry as a bone & no hiss (still dry with bleed nipple totally removed, tried with both expansion cap on & off). Surely this isn't right? With engine running... coolant is returning to expansion tank & the radiator gets hot, so there is a "circuit" pumping through? Comments pls folks.Passenger side in the front. Use the bleed valve on the hose that goes to radiator.Level raising was more like a high pressure torrent of magma! Expansion went from 1/3 to over 1/2 full in a couple of seconds. Best route for clearing trapped air?You may have some air trapped in the system somewhere. Hence the level raising when you release the pressure.
#36
Posted 19 May 2013 - 05:13 PM
Is that with the engine up to working temp? Bleeding must be done hot.
#37
Posted 19 May 2013 - 06:35 PM
Cheers for getting back to me Boombang. Yep. Bled at working temp. Also did the old "squeeze every pipe with engine running and expansion tank cap off" routine. Re-fitted cap. Bled again. Radiator Nipple bleed still dry. Even tried blowing into expansion tank. Now thinking I may fabricate a cap with a valve on it (from an old inner tube). Slightly overfill expansion, fit it, bring up to temp, open all bleed valves, force pressure through system with foot pump... Theoretically blowing out all air locks.Is that with the engine up to working temp? Bleeding must be done hot.
#38
Posted 19 May 2013 - 06:40 PM
Edited by Sticky, 19 May 2013 - 06:40 PM.
#39
Posted 19 May 2013 - 06:42 PM
Rad is hot. After 5-8 mins ticking over. Tick over temp stable around 85-92.Is your rad hot/warm with coolant flowing through?
#40
Posted 19 May 2013 - 06:43 PM
Coolant appears to be flowing through, as it is returning to expansion tank (top hose). Can't hear it gushing with ear to rad (plus rad too hot to put ear too!).Rad is hot. After 5-8 mins ticking over. Tick over temp stable around 85-92.Is your rad hot/warm with coolant flowing through?
Also tagged with one or more of these keywords: coolingexpansion tank, overheat, engine temp, hoses, pump, thermostat, radiator, na
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
The Market Place →
Car Parts Wanted →
2002 Vx220 - 2.2 - Need Abs Pump - Northern IrelandStarted by mpet72 , 03 Nov 2020 ![]() |
Welcome to VX220.org.uk →
Introduce Yourself - Newbies & Forum Guide →
Hello From Leamington SpaStarted by Jordang , 22 Aug 2020 ![]() |
The Market Place →
Car Parts Wanted →
Na HeadlightsStarted by jdscott , 02 Aug 2020 ![]() |
General Discussion →
Tuning & Modifications →
Bizarre Acceleration IssueStarted by MattMacc123 , 10 Aug 2019 ![]() |
