Project Black Bat
257 replies to this topic
#1 Ormes
Ormes
  • 4,612 posts
Posted 19 May 2013 - 02:49 PM
Hi .org, after nearly 3 years of ownership, I thought it was about time I started a project thread to document my beloved Tubby.
Background:
In 2010 I reached a bit of a crossroads after having owned nothing but hot hatches and laterly, barges.  After owning several Hondas, my Accord 2.4 Exec decided it would present me with gearbox gremlins, and so I had an urge for something different.  A number of cars were on my list including BMW Z4M, Nissan 350Z, BMW 335 Coupe, and of course VX220's were on the list after a colleague had 3 of them, and I had the pleasure of being a grinning passenger.
Driving around, visiting garages with a fairly open mind, I spotted a Black VX220 Turbo on a forecourt and popped in for a quick look... 4 hours later, and after the most thrilling drive home of my life, it was on my driveway :D 10 minutes after I got home, I joined the forum I had been lurking in :)
I used her as a daily for around 10 months before promoting her to a weekend car.
During my ownership it is fair to say that I have spent 10 times longer, working on, and cleaning the VX than actually driving her, which for me, has been extremely enjoyable, and has given me more confidence to tinker around mechanically.
I will begin by documenting its original spec, what I have done over the last 2 years 11 months, and will then keep this thread up to date with future developments :)
It is worth stating my overall project brief (for now :) ) - "A very tidy Stage 2 that handles and stops well".
Original spec (at the time of purchase): -Completely standard 2004 Sapphire Black Turbo with just over 20k on the clock and FVSH. -Grey Cloth -Central Locking
Thanks for reading :)
#2 Ormes
Ormes
  • 4,612 posts
Posted 19 May 2013 - 02:54 PM
A month after purchase, it was in with Mike at SCS in Halesowen for:
    [*]Full Service including Cam Belt and brake bleed.
    [*]Stainless steel brake pipes
    [*]Geo
    [*]Anti rattle door pins
    [/list]
    Since that point, it hasn't seen a garage/workshop for anything other than an MOT.
    I have done a number of routine things that I've not listed below, such as oil services, changed the plugs a few times (NGK Iridium 6), changed the tyres, changed the brake fluid a number of times, changed a number of fixings, tidied a number of things up, and got rid of a few rattles.
    Here are the main things I've done so far:
      [*]New header tank and level sensor
      [*]Header tank cover
      [*]New Stereo and Speakers
      [*]Black bolts on fuel surround
      [*]Flat wiper blade
      [*]HID dipped beam
      [*]99 VW wiper relay
      [*]New heater duct (the sh!t ebay one)
      [*]Vinyl wrap windscreen surround & sunstrip in Matt Black (thanks Brett)
      [*]ABS cut-off switch
      [*]Powerflex engine mount inserts to front and rear
      [*]Forge recirculation valve to replace original rubber one
      [*]New solenoids (boost and intake)
      [*]Fan override switch
      [*]Proalloy intake pipe
      [*]RC5+ Pads and Pagid disks machined with J-hook (previously I'd installed 1144's)
      [*]Apexi dry foam cone filter (after having previously drilled my standard box to buggery, and briefly used a Courtenay foam panel filter)
      [*]Fire extinguisher on a custom bracket that I made
      [*]Nitron Street series (thanks Jimmy)
      [*]Scan gauge
      [*]Removed front V
      [*]Removed rear Griffin
      [*]Brand new damped crank pulley (after having previously installed lightened ones)
      [*]New aux tensioner, idler pulley and belt (after having previously made the old ones redundant)
      [*]Courtenay cam to sump breather (after the previous one failed)
      [*]Courtenay plenum/tophat and silicone IC to tophat pipe
      [/list]
#3 Ormes
Ormes
  • 4,612 posts
Posted 19 May 2013 - 02:56 PM
A few pictures :)
#4 Nev
Posted 19 May 2013 - 04:16 PM
We already have a "Batman" on here, so you must be Robin ! LOL
#5 hairy
hairy
    Moonlander
  • 6,004 posts
Posted 19 May 2013 - 04:42 PM
Looking good Alex thumbsup. Stage 2 coming up?
#6 Ormes
Ormes
  • 4,612 posts
Posted 19 May 2013 - 04:49 PM
Cheers Hairy thumbsup 3" 2bular is ordered and paid for, and once it arrives at MMG I will be trecking up t'North for fitting and a Stage 2 map :D
#7 JG
JG
  • 13,612 posts
Posted 19 May 2013 - 06:30 PM
thumbsup Alex.
looking forward to seeing the progress. :)
#8 Ormes
Ormes
  • 4,612 posts
Posted 19 May 2013 - 07:54 PM
Cheers James thumbsup
UPDATE: Forgot to mention the SPLAM grill :) (Cheers Sam)
#9 Ormes
Ormes
  • 4,612 posts
Posted 15 June 2013 - 01:43 PM
UPDATE: Fitted the following:
-Stack Boost Gauge
-Stubby black aerial
-AndyWilson stainless water ingress cover (cheers Andy)
-Gloss black TD 1.2 16/17 with AD08's (cheers JG)
thumbsup
#10 Ormes
Ormes
  • 4,612 posts
Posted 15 June 2013 - 05:53 PM
A few pictures from my last update:
TD's fitted:
AndyWilson water ingress cover fitted:
Stack boost gauge fitted:
thumbsup
#11 Rickwoo118
Rickwoo118
  • 5,800 posts
Posted 15 June 2013 - 06:05 PM
Nice one....looks good. Once you have started modding it is dangerous......stage 4 coming up??
#12 Ormes
Ormes
  • 4,612 posts
Posted 15 June 2013 - 06:18 PM
Cheers mate thumbsup ...one step at a time :) ...It is going into MMG on 25th June for a stage 2 :D
#13 Rickwoo118
Rickwoo118
  • 5,800 posts
Posted 15 June 2013 - 08:40 PM
Here's my black bat..
#14 Bumblebee
Bumblebee
  • 7,592 posts
Posted 15 June 2013 - 08:41 PM
Which is now known as the black bullet ;)
#15 Rickwoo118
Rickwoo118
  • 5,800 posts
Posted 15 June 2013 - 09:23 PM
Nice one....will refer to that ....sounds good!
#16 Wreelybro
Wreelybro
  • 1,641 posts
    360 Gaming 10-Pin Bowling.
Posted 17 June 2013 - 02:28 PM
Looks great in black would be my choice if I'd not gone with white. Black cars shine so well!
#17 Ormes
Ormes
  • 4,612 posts
Posted 17 June 2013 - 05:27 PM
thumbsup
#18 Ormes
Ormes
  • 4,612 posts
Posted 25 June 2013 - 10:20 PM
Dropped her off at MMG today :) Can't wait until Friday 5th July when I collect :D
#19 Nev
Posted 27 June 2013 - 09:18 AM
Better spend the intervening time productively, by shopping for some new rubber underpants then :)
Hehe.
#20 Ormes
Ormes
  • 4,612 posts
Posted 28 June 2013 - 05:47 AM
Hehe.
