A few updates:
Some time ago, whilst doing a track day at Castle Combe, I bought some SPA wing mirrors, at which point I discovered that fitting them in a clean way was not going to be as simple as I first thought. Part of the problem was that the paint beneath the old mirrors was rubbed and so the brief for the new design, was:
-Must use all OE fixings, so no drilling the car.
-Must look as OE as possible, and sit flush with the compound curve of the mouting base and the door.
-Must cover the footprint of the existing mirror to avoid the need for paint correction on the car.
Set about using my ameature 3d skills in 123D Design (Since moved to Fusion360 for later projects), and came up with a 3 piece design that consists of a base to absorb the curve of the mounting area, a steel mounting assy that everything bolts to, and cap that covers it all up and clips to the base.
I must confess that I nearly wet myself on occassions, as various bits arrived from the 3d printers, laser cutters, and my (kitchen) workshop, and all came together to be something that fits, and that I'm actually happy with. Some pictures of the process below
The design:
(continued...)
