Project Black Bat
257 replies to this topic
#221 vocky
Posted 14 May 2018 - 06:20 AM
a nice solution, quite time consuming but probably quicker than trying to find and buy a new headlight
#222 Ormes
Ormes
  • 4,612 posts
Posted 14 May 2018 - 06:50 AM
thumbsup
#223 Doctor Ed
Doctor Ed
  • 1,188 posts
Posted 16 May 2018 - 10:47 AM
i had to double take to see if you just hadnt reposted my pics!
http://www.vx220.org...0nft/?p=1852473
What I ultimately came up with:
Continued...
#224 Ormes
Ormes
  • 4,612 posts
Posted 16 May 2018 - 01:52 PM
WHAT THE ACTUAL F***?
1) I wish I had seen this before spending weeks coming up with the same idea
2) You must be a brother from another mother
:o :o :o :o :o
#225 hairy
hairy
    Moonlander
  • 6,004 posts
Posted 16 May 2018 - 06:52 PM
Great minds!
#226 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 18 May 2018 - 02:29 PM
:o :o :o :o :o
You're father did a lot of 'business trips' in the past??  :P
#227 Ormes
Ormes
  • 4,612 posts
Posted 30 June 2018 - 10:26 AM
Small update:
R888R's fitted this morning :) Having been on AD08s for the last 5 years, looking forward to trying these!
#228 Nev
Posted 30 June 2018 - 05:19 PM
Fancy trying them tomorrow? I'm off for a 300 miler round mid Wales, let me know if you're interested. 4:15 AM start though!
Edited by Nev, 30 June 2018 - 05:19 PM.
#229 Ormes
Ormes
  • 4,612 posts
Posted 01 July 2018 - 08:46 AM
Sorry bud, I'd was still well over the limit at that time ;)
#230 Ormes
Ormes
  • 4,612 posts
Posted 21 July 2018 - 11:21 AM
Update: Finally fitted my Matthew Bently Racing ARB
Knew I cut down that allen for a reason :)
Works a treat, didn't have to loosen wishbone bolts as mentioned in guides on here:
ARB mounts came off easy enough but had a major argument with the drop links!
Continued...
#231 Ormes
Ormes
  • 4,612 posts
Posted 21 July 2018 - 11:22 AM
Obviously cleaned everything to within an inch of its life before fitting, including sanding the rust that had formed on the ARB through storage, and under the car.  Also capped the ends of the ARB with Sikaflex to stop it rotting from the inside, as suggested by Chris Redman thumbsup:
Continued...
#232 Ormes
Ormes
  • 4,612 posts
Posted 21 July 2018 - 11:23 AM
Have since driven the car, which feels fine :) I don't push hard enough on the road to really notice the difference :)
#233 MAXR
MAXR
  • 2,719 posts
Posted 19 August 2018 - 05:36 PM
I like your mirrors solution. Way too much work for me at the mo.
I have just removed my OEM mirrors & cut off the mirror & hinge mechanism from the triangular base & I’m now going to fit a lightweight mirror to the base.
I’d prefer to have my mirrors sticking out further. That said, I’ve recently bought an 8” screen & rear view camera for track use as I’ll have a coupe back with VERY limited rearward visibility.
Also, it will allow me to see Joe shrinking to a small dot when he attempts & fails to catch me.
#234 Ormes
Ormes
  • 4,612 posts
Posted 19 August 2018 - 06:13 PM
thumbsup
With hindsight... I'd have made the mirrors stick out further!
#235 Rosssco
Rosssco
  • 4,183 posts
Posted 20 August 2018 - 01:56 PM
Are Exige V6 mirror bases compatible, as they push the mirrors a bit further out IIRC..
#236 Exmantaa
Posted 20 August 2018 - 04:35 PM
The Elise S2 mounting plinths also are a bit wider than stock VX:
http://www.elise-sho...h-lh-p-375.html
#237 Ormes
Ormes
  • 4,612 posts
Posted 20 August 2018 - 05:09 PM
thumbsup
#238 Arno
Arno
  • 1,238 posts
Posted 21 August 2018 - 07:12 AM
You will need to sand down a little of the bottom edge of the S2 plinths to correctly fit on the VX door as the latter curves out sooner than the Elise does.
 https://www.verboom.net/projects/speedster/20051101/index.html
No biggie, but otherwise the screw/bolt holes won't line up properly and it won't sit flush on the bottom.
#239 Ormes
Ormes
  • 4,612 posts
Posted 10 September 2018 - 03:25 PM
Update: Changed Oil (Mobil 1 5w30 ESP) + Filter (Genuine Vauxhall) - 10/09/2018.
#240 Ormes
Ormes
  • 4,612 posts
Posted 15 September 2018 - 01:57 PM
Update: Changed front brake pads as they were looking a little low... lasted 6 track days and about 2000 road miles.  CL5+
thumbsup
