Project Black Bat
257 replies to this topic
#21 2GOOD
2GOOD
    Old Timer zzz...
  • 4,451 posts
Posted 28 June 2013 - 07:25 AM
Looks lovely, I hadn't seen this thread before. Did you fit the performance enhancing Lotus performance spark plug cover aswell Alex? :D
#22 Ormes
Ormes
  • 4,612 posts
Posted 28 June 2013 - 08:03 AM
Thanks :) I did yes... Old one was tired and the lotus one came up and was cheap... Adds at least 10bhp :D thumbsup
#23 2GOOD
2GOOD
    Old Timer zzz...
  • 4,451 posts
Posted 28 June 2013 - 04:00 PM
:o Only 10bhp??? I'm sure that Dick Lovett's told me it was worth more than that when I bought mine :D
#24 Ormes
Ormes
  • 4,612 posts
Posted 05 July 2013 - 08:07 PM
UPDATE: Just picked her up from MMG after the following work... -2bular 3" exhaust (turbo back) -Wrapped ubend -Cambelt -Water pump -Aux belt -Coolant -Oil and filter -Spark plugs -Engine mounts -Hub carrier bolts -Toe link assemblies -New spring for forge recirc valve -Stage 2 map (243bhp) -Full geo incl. Ride height, damping, camber and toe Car is feeling sweet :) Love the sound of the 2bular, not noisy when cruising but lovely when you hoof it :) Enjoying a dose of extra power. thumbsup
#25 Ormes
Ormes
  • 4,612 posts
Posted 27 July 2013 - 09:58 AM
Well, I have now done my first track day with the National at Pembrey :)
Car felt great... pulled like a train all day and handled sweet.  I still can't get over the grip levels and was taking it easy to be honest (driving within my track experience level!)
Once the car gets track warm, the exhaust makes some rather loud bangs :D ...which I like in a chav kind of way :)
Love the AD08's, albeit I seem to have collected some massive lumps of rubber which I need to peel off at some point.
#26 Nev
Posted 28 July 2013 - 04:01 PM
Thanks again for the passenger rides Alex :o)
#27 Ormes
Ormes
  • 4,612 posts
Posted 28 July 2013 - 04:41 PM
Any time Nev... why the shocked smiley? :)
#28 Nev
Posted 28 July 2013 - 06:42 PM
Appologies, my mistake, it was meant to be a normal smiley, but I put a "o" in it and it came out like that. What I really meant was... :)
Edited by Nev, 28 July 2013 - 06:46 PM.
#29 Ormes
Ormes
  • 4,612 posts
Posted 23 March 2014 - 02:52 PM
Been a while since I updated my project thread...
Since my last update I have done the following:
-Was getting P0420 code thrown up once in a while since the 3" 2Bular was fitted, so removed the Lambda and cleaned the connection up, been fine since (touch wood).
-To fit the 3" 2Bular, MMG had to space the undertray (using washers wrapped in insulation tape) and increase the size of the hole for the flexi joiner.  I bonded some spacers to the tray and tidied up the hole that MMG cut.  Also tidied up the nimbus type backbox heat shield, as again this needed to be cut to fit the exhaust.
-Today I removed the useless and poorly fitting eBay heater pipe and replaced as per the pictures below... retained the sieve modification I did to the ebay kit and all fits lovely now :)
thumbsup
#30 Ormes
Ormes
  • 4,612 posts
Posted 12 April 2014 - 03:15 PM
Just caused myself incredible discomfort and hassle... and changed my battery... the old one was 4 years old and starting to lose charge.  I got a Yuasa Silver 5000 (5 yr warranty).
Had to undo the fuse boxes from the arch liner, clip several cable ties, undo the brake servo line, undo heater pipe, remove washer motor shroud, remove washer bottle, remove ctek wires from battery, remove terminals from battery, and generally break myself, hunched over, trying to hold the cables back and pull the f*cker out at an angle.
Then had a bit of a clean...
Then put in the new battery and connected the terminals... car armed its self, beeped at me, then a minute later the alarm went off.  Been out on a little drive, and everything seems fine :)
thumbsup
Edited by Ormes, 12 April 2014 - 03:30 PM.
#31 Nev
Posted 14 April 2014 - 08:07 PM
Arghh, you haven't put a strap under the battery for the next time you have to take it out ! LOL Well done, its a bitch knuckle scraping back bending job.
Edited by Nev, 14 April 2014 - 08:08 PM.
#32 jules_s
jules_s
  • 15,275 posts
  • Interests:Plane spotting
Posted 14 April 2014 - 08:10 PM
It has a handle :lol:
#33 Ormes
Ormes
  • 4,612 posts
Posted 14 April 2014 - 08:35 PM
Cheers Nev :) hopefully something I won't have to repeat for a while.
As Jules spotted... thankfully it does have a handle :lol:
#34 fezzasus
Posted 15 April 2014 - 09:00 AM
I've only come across one handle-less battery in the 60-odd heaters i've fitted.
(BTW, takes me about 2 minutes to take one out, don't know what you all complain about)
#35 Nev
Posted 15 April 2014 - 11:12 AM
I must be going blind as well as stupid! When I changed mine I think the handle had either snapped or wasn't there, which is why I had such a strong brain fart about sticking a strap under it.
#36 2GOOD
2GOOD
    Old Timer zzz...
  • 4,451 posts
Posted 15 April 2014 - 11:29 AM
I've only come across one handle-less battery in the 60-odd heaters i've fitted.   (BTW, takes me about 2 minutes to take one out, don't know what you all complain about)
You've had lots of practice! :P Couldn't believe how quickly you had my battery out after the fun & games I'd had a couple of weeks earlier.
#37 Ormes
Ormes
  • 4,612 posts
Posted 09 June 2014 - 06:07 PM
Worked myself into an unfortunate corner through being too busy :(
Needed to swap the cat back in to MOT her at the end of April... didn't start doing it until the end of May.  After some swearing, I've removed the lambda, and 2 bits of exhaust ready for the cat to go in, ran out of time, so here I am mid-June and still not back on the road.  Tax up at the end of June so looks like I'm SORNing her too... and all that at the start of summer.
Must do better.
#38 hairy
hairy
    Moonlander
  • 6,004 posts
Posted 09 June 2014 - 06:43 PM
Doh!
any tips for lambda removal, or did it come out fairly easy?
#39 Ormes
Ormes
  • 4,612 posts
Posted 09 June 2014 - 07:04 PM
Hairy... it was easy, but the exhaust is a year old and I'd had the lambda out previously (also relatively easily).  The b1tch was seperating the bits of exhaust... sleved joint, and very snug!  thumbsup
#40 Nev
Posted 09 June 2014 - 07:07 PM
Let me know if you need an extra set of hands Alex. Any time.
